ccityinstaller
- Feb 23, 2007
Welcome to the suck lol
I would suggest removing the advmethods flag from your client, stick to standard A3s until Stanford addresses the issue, leave the 67xx units to guys with monster rigs
Posted via [H] Mobile Device
You sure it's the same unit? Maybe you got a random flop, I've seen guys get those before
Where did you get this information?Removing the -advmethods flag will not prevent you from getting P6701 and P6702 units.
From the fact that I am not using the -advmethods flag and I'm still getting them?Where did you get this information?
Hmm, very interesting, It's been close to two weeks and haven't seen hair or hide of one across 6 clients. I guess I could have overlooked a WU or two, I don't have my eye on every system all the time. Mind you, I did remove it from the client config as well and believe that you need to do this to make the setting effective. Therefore, a few possibilities remain to explain the difference between our two experiences...From the fact that I am not using the -advmethods flag and I'm still getting them?
You really think I wouldn't have noticed that?A. you don't have it removed form the client config
No, I was pretty certain you would have, but it was one possibility among the list and I had to include it for the sake of completeness. I'm thorough that way.You really think I wouldn't have noticed that?![]()
On a side note, does anyone know what local means in the client.cfg file?
These units were not pulled.I just assumed that was a bad WU, considering they pulled them not too long ago.
Stanford cites their benchmark machines being responsible for the odd evaluation of WUs, but I never understood how such large discrepancies can occur. If we use our own machines, whether it's an i5, i7 or older Core2 architecture, a slower WU will take more time to complete. It's universal. The only difference between systems is the length of time. Longer running WUs need to have their values adjusted accordingly by increasing their base value and/or bonus to reflect this, not the contrary. I just don't get it and we're not alone.While Stanford did increase the absolute/preferred deadlines on these units recently to accommodate dual-core SMP CPU folders, they continue to be a mystery as to WHY their performance is so much lower on Core I7s and other 6+ core boxes.
I understand they bench these with an I5 750, but it still doesn't explain the 25 to 40% PPD reduction over P60xx units. Even P604x larger A3 units show a lot more PPD.
There's obviously something wrong with the benchmarking process, because if all units are supposed to produce the same PPD on a 750 then 750 machines shouldn't be taking PPD hits with any of these units.
