GJSNeptune
- Mar 31, 2004
I posted this in Networking & Security, but none of the 30ish people who've read it have responded, and I'm beginning to think it's more of a hardware issue. Before I thought it was a drivers conflict or something (hopefully, maybe it still is), but after Googling, it seems it's actually pretty common for the P5Q boards.
I have no idea what happened. I had just set up my new Asus VW266H monitor. I turned on my computer and loaded Firefox. I Googled for Dead Pixel Buddy, and suddenly I was getting error messages about not being able to load webpages. I went into Control Panel to repair the LAN, and still nothing. I rebooted a couple times. Now my LAN doesn't even show up under Network Connections. I've repaired and uninstalled/reinstalled the Atheros LAN drivers several times. I even tried the latest version. My Gigabit LAN is enabled in BIOS. Under Device Manager, only my 1394 network shows up under Network Adapters.
I did have uTorrent running at the time because it's set to start with Windows, but I've never had problems, and I only use it to download (legally) taped concerts in FLAC format. I highly doubt I downloaded something malevolent.
I'm using Windows XP 32-bit. I've had this rig going for about two and a half months now without issue. Now my network adapter is broken? I've Googled but haven't come up with anything beyond what I've tried.
The ethernet port has a mostly-solid yellow light. It'll flicker occasionally. I don't know enough to know about RJ45 ports, but I'm guessing the LED is independent of whether or not the adapter itself is working.
I've tried just about everything. I guess my onboard NIC died. I came across a Microsoft support page, and tried some things. After nothing worked, it told me I could use the CMD console to show hidden devices in the Device Manager. The Atheros network adapter was indeed faded out, and the Microsoft page told me to uninstall it. So I did. I rebooted, but Windows didn't detect it to add it again, so I can't even mess with LAN drivers because they don't detect the device.
Anyone have experience with Asus RMA, or should I buy a NIC?
