Raji earlier today on XS said:The pin holes are from the Foxconn socket. The scuff marks likely when the CPU is first instered into the socket or direct from Intel.
Raji replying to a comment on his article tonight said:yeah the pricks are from factory CPU's. The Foxconn head contact should leave a small scuff mark on every pad, but it does no seem this always happens due to incorrect loading.
I'm not really sure if there's even a problem here.
This whole issue has me scared for my new 860.
Confirmed that the little intentions are from the factory.
That is all.
will be interesting to check what intel themselves use, they have used many foxconn parts before, even some of their boards are made by foxconn.
They are quite anal about making their intel branded boards last for years without any trouble. (although you cant overclock most of them the power pins are there for a reason)
So people that already have boards with Foxconn sockets... what are you going to do?
Raji said:Word is that Foxconn have changed the socket top plate in a revision to correct the problem. Not sure that it is trouble free now as someone in mainland China had a problem on the revised socket too. What I do know is that DFI, EVGA and MSI have moved production over to other socket vendors.
Raji said:thats the part Lathode that is all under wraps. I've had two vendors come forwards and show me what Foxconn sent them. Foxconn claim the issue was identified in May and that Intel were due to revise their design to rectify. Apprently these were supposed to be sample sockets with the issue and all issues were supposed to be in house in some vendor labs. Since then there have been issues reported on what is supposed to be the revised Foxconn socket (or samples that have gone into the wild on retail boards), so I'm not sure what to believe at this point. What some of the vendors have seens themselves is not centric to an earlier model or revision of socket.
I'm convinced there's a problem, but I'm not convinced it's systemic.
Raju's evidence may have been wrong (the pin hole indentations), but his conclusion may still be right (some Foxconn sockets might provide insufficient contact).
The burn-out pictures are hard to ignore, but less than a dozen cases have been reported. Considering the ubiquity of the Foxconn parts, the number of failures is not very concerning.
These boards have been out for over a month; if the issue was widespread, the forums would have been overrun a long time ago.
Since my board is running fine, I have no intention of returning it. I'll continue running at 4.1Ghz. If my socket combusts, I'll report it here immediately.![]()
Will you keep running what you have, or order a new board?
It would cost me $90.50 to return the Asus P7P55D Pro for an Evga P55. $25.50 (15% restocking fee) + $25 (combo discount taken back) + $10 (ship board back) + $30 (cost difference between P7P55D Pro and P55) = $90.5
I have a custom built i5 750 desktop with the Gigabyte GA-P55-UD3R motherboard that will be arriving to my home this week and I'm not planning to overclock the cpu. Let me get this straight, I won't have any burnt sockets because I not going to overclock the CPU.
I like to get one LOTES kits installation and remove Foxconn with 3 screws out then pop in new one with LOTES, sound pretty easy swap it.
I honestly don't think you'll see any kind of recall unless it can be shown that it's harming non-OCed chips, because I'd think they could all fall back on the "hey, we warned you in the manual that you OC at your own risk".
I have not read the whole thread but if it were me I would not believe the retention mechanism is the problem more like the pins themselves.
Encouraged by a far-lower TDP rating on the new generation of Core i7 processors (95W, down from 130W), these companies probably designed LGA 1156-based models with a similar percentage of “overcapacity” as they’d used on LGA 1366 boards. But the fault doesn’t sit solely with each motherboard’s initial design team, as testing should have revealed the problem before the boards reached mass production or distribution.
Maybe a better question would be “what’s missing”? It seems that many of our previous-generation motherboards would shut off when overloaded, before anything was damaged. That’s called over-current protection, and it’s a feature apparently now reserved for high-end boards.
But did we push too hard? Remember that these settings were achieved using air cooling while keeping the CPU below its thermal-throttle threshold. Air-cooled overclocks certainly aren’t considered “extreme.” And for those wondering, the side of the VRM that burned in every case was the same side upon which the CPU fan was blowing strongly. This once again demonstrates that a voltage regulator should never be designed so that it can output more than its peak capacity.
Because three of the failures occurred at or below 1.40V, we have no knowledge of what to recommend as a “maximum safe” voltage for overclocking these three motherboard models. In the future, we’ll allow motherboard manufacturers to specify any lower “maximum” settings that may be required to preserve their products and will then duly arm readers with that information.
Update: ASRock confirmed that its P55 Pro was designed to handle a smaller power load, based on Intel's lower TDP for LGA 1156 processors, and has sent a BIOS its representatives claim will enable built-in over-current protection. To make sure that all three companies have an equal opportunity to address this issue, we have given them all two weeks to come up with a solution and will publish an article that addresses the new overclocking limitations.
i am not sureapoppin - Did Tom's check for socket burn as well? Either way if it's related - it sucks. If it's not related, that's a second separate issue to worry about, and as low as 1.36Vcore. This is laughably bad - I'm almost expecting more and more bad news to come out.
we don't know this for sure, do we? - Tom's HW appears to be reporting different issues with 3 different mobo manufacturers on AIR overclockingI am NOT surpised at all that this issue is only on the Foxconn sockets....
I refuse to buy any boards sold by Foxconn and cringe when I see people with OEM boxes since most OEM motherboards are made by Foxconn.
I did onsite repair for Dell and some for IBM over a 2 year period. The crappy quality of the Foxconn boards made me never ever want to buy an OEM box for any reason whatsoever.
Are we sure it is just the socket?
- it makes me really glad i just got i7 920/s1336 or i would return the p55/i5 i was considering
Tom's hardware is reporting multiple defective motherboards from 3 different manufacturers and they are not LN2 or water cooled;
http://www.tomshardware.com/reviews/budget-p55-motherboard,2436-15.html
(quoted in part)
(quoted in part)
huh? did you read the article?They found that problem on Asrock's X58 Supercomputer, it's not related to the Foxconn P55 sockets.
That's something different. Those were cheap boards that couldn't handle the power. Tom even states ASRock told them the board was designed for lower power and so they made changes to the BIOS. Higher end boards do not have this issue.
Doesn't Foxconn make most of the Intel sockets - including for Intel's own mobos?
Tom's article is all about *multiple* P55 motherboards burning up with the CPU mildly overclocked on AIR cooling
From these manufacturers:
ASRock
MSI
ECS
IF they all have Foxconn sockets, THEN it is the socket (probably)
- if not, it is possibly Intel's design issue - don't say it is because they are "budget" mobos, either. All *3* different manufacturers plus the ones Anandtech detailed.
The article is about the power regulation on P55 motherboards burning up, a problem which has been seen before on an X58 motherboard. So yes it is a problem on multiple low-end P55 motherboards, but is not confined to P55 or even low end boards. It is also a separate issue from Foxconn 1156 sockets, and is vendor or BIOS specific, not socket-specific.
Once they get this sorted out, you will be OKSo... should i save the >$150 and go i5 or spend an extra >$150 and go i7 this holiday season?
(quoted in part)
