P4 Power Supply
This psu has a 20+4 pin connector. My motherboard requires a 4 pin connector, can i use the +4 pin connector for 4 pin on the motherboard?
No. Also, the PSU does come with a 4Pin CPU power connector in the form of a 4+4 connector. You can just remove the +4 and then you'll have a normal 4Pin CPU power connector.
that is what i was asking....can i use the +4 pin connector for the cpu 4 pin on the motherboard?
From the 20+4 connector? No. They are wired differently, and delivar different voltages.
Again, you cannot use the +4Pin connector of the 20+4Pin power Connector in the 4Pin CPU Power connector.
yes i read that.
the only reason i asked is because tiger direct website stated that it did not have a p4 mb connector.
Well, as you may have figured out, Tigerdirect is wrong.
you know...this is like the 3rd time i have caught something like this at tiger direct...whats wrong with those guys?
