P4 mobo recommendations for games
EmilG
Well I'm starting up my every couple year search to put together a new system. I'll be upgrading my mobo, P4, ram and vid card. Any suggestions for a starting point for a mid priced mobo & P4, I'm kinda partial to Asus but that can change.
Thanks
P4 ? you have been away for a while.
Gigabyte P965-DS3 (or -S3 if on budget)
Core 2 Duo E4300
any decent PC6400(800MHz ram)
Artic freezer fan/hs or Thermalright 120
I am sure an Asus fan will drop by and give you the hot asus version.
Core 2 Duo E4300
That's a quality low end core 2 setup. Even though I am running an asus right now, it works but it's not my fav board of all time. I've had 2 friends use the DS3, its a quality board :)
OP what's your budget for everything? is SLI going to be considered? I'd say any system built these days for any type of gaming should be equipped with 2gigs of ram. You'll most likely need a new PSU as well unless your current one is >550 or you're not putting in a higher end video card.
P4, yah, many things have changed in two years :).
I've have a gigabyte video card and had no prolems with it so no problem with them.
Thinking about it, even though I haven't had an AMD it's not out of the question either.
Forgot about the PS, good suggestion, I'll definitely add that to the list too!
I thoughtt gaming was basically single thread so wouldn't it be better to sink extra cash into a higher cpu speed or better video card? Has this changed too :)?
Yeah for now gaming is still pretty much single threaded. But windows and many other programs are now multi-core aware and can take advantage of them. And soon games will start doing the same. Valve supposedly has a multithreaded version of the source engine in the works. As more time passes more games will come out with support. So I think dual core is a very good investment.
And I hope your video card is PCI-E and not AGP, or you'll need a new video card.
The good Asus boards are the:
P5B-E - $150
P5B Deluxe - $170
P5N-E SLI - $135
The only real advantage the P5B's have over the DS3 is the ICH8R with some extra SATA ports and RAID controlled by the Intel controller rather than a 3rd party one. The SLI board has an IDE channel (or two...don't remember) built into the chipset rather than a 3rd party one like on the rest of the 965 boards.
P5B-E - $150
P5B Deluxe - $170
P5N-E SLI - $135
The P5N-E SLI has 2 IDE's. It's a pretty solid board overall, but overclocking requires a fan over the northbridge to keep it cool. But my core2 runs stable at 3.5ghz, watercooling helps alot :D
Thanks for the suggestions guys.
Any comments on the AMD processor or should that one go in another forum?
Thanks again.
Thanks again.
What about them? There's really no reason to go AMD unless you're on a budget and want the X2 3600+/mobo combo for under $150.
If you've EVER thought about overclocking even once, then you should go core2 unless you absolutely can't afford it. Then AMD is your next best choice over the Pentium 4's and Pentium D's.
I ordered the following:
E6600 2.4g
Asus P5B-E
EVGA 8800gts 320m
Patriot 2gb ddr2 800m
Antec case and ps
Floppy
(keeping my old Raptor and DVD drive)
with rebates and shipping just a tad over $1000
Now the hardest part, waiting for it :)
Thanks for the suggestions !
E6600 2.4g
Asus P5B-E
EVGA 8800gts 320m
Antec case and ps
Floppy
Not a bad system for the price.
Looking at some signatures I can see the E6600 overclocks pretty good :).
Kinda like the old P4 I had, it was a 1.6g but everyone ran them at 2.13g.
