Hi,
I have a question for you guys:
I was playing Global Agenda during the week end on the computer in my sig.
My game was crashing every 10-15 mins (computer was just off, no CTD, no BSOD, no reboot, just being turned off).
This was not happening with any other game (MW2, Singualrity, Lotro, AoC, etc ).
So my first step was to put the video settings to low for Global Agenda and see if it would make a difference (besides the graphics looking like utter crap lol).
Computer still crashes.
So I tried the good old fan trick. I opened up the side of my comp, and put a fan there, blowing directly on my motherboard.
I was able to play the game without any problem for at least 2 hours. So, I had it figured out: its due to overheating.
After a while, I decided to turn my graphics to high settings again. The game looked really good after playing on low settings for like 2-3 hours.
But then, the game crashed again after 10 mins or so.
My question is this:
Would getting a new video card fix my problem? And if yes, what would you recommend that would be a significant upgrade for me, without making me spend more than about $250.
Thanks!
Thanks!
