SegFault82
- Oct 9, 2007
Hi all, I'm currently running my system overclocked but was hoping to get more help & advice from all the experts here so I can oc it higher. And also clear up some issues I'm having. I'm gonna post a crap load of info, so here goes. First of all, system specs:
Intel Q6600 Stepping B Revision G0 - 9x333, vcore @1.28125
Tuniq Tower 120
ASUS Striker Extreme Rev A2 (BIOS 1303)
4GB(4x1) OCZ DDR2 1066@667MHz (1:1)
EVGA GeForce 8800GTX 768MB @576MHz
Western Digital Caviar 500GB WD5000AAKS
Antec 900 Case
Antec True Power Trio 650W PSU
It's running pretty stable right now with the below BIOS settings. I ran prime95 for about 12.5 hours with no errors. During that 12 hour session, the maximum temperatures I saw in Core Temp were:
core 0: 56 core 1: 54 core 2: 54 core 3: 51
IDLE temps are:
core 0: 39 core 1: 35 core 2: 37 core 3: 34
Anyway, now for the BIOS settings in the Extreme Tweaker menu:
SYSTEM CLOCKS:
PCIEX16_[123]: 100MHz
SPP<->MCP Ref Clock: AUTO
FSB AND MEMORY CONFIG:
Memory Clock Mode: UNLINKED
FSB (QDR): 1333
MEM (DDR): 667
OVERCLOCKING:
Multi: 9
Memory Timings: 5-5-5-15
CMD: AUTO
Advanced Memory Settings: ALL AUTO
Spread Spectrum Control: ALL DISABLED
CPU Interal Thermal Control: AUTO
Limit Cpuid Maxval: DISABLED
Enhanced C1 (C1E): DISABLED
Execute Disable Bit: ENABLED
Virtualization Technology: DISABLED
Enhanced Intel Speedstep: DISABLED
LDT Frequency: 5x
OVER VOLTAGE:
Vcore: 1.28125
Mem: 2.1
1.2v ht: 1.2
NB core: AUTO
SB core: AUTO
CPU vtt: AUTO
ddr2 controller ref: AUTO
ddr2 channel a ref: AUTO
ddr2 channel b ref: AUTO
SLI Broadcast Aperture: DISABLED
Nvidia GPU Ex: AUTO
Ok, now for some temp and voltage readings:
BIOS VOLTAGE READINGS:
Vcore: 1.24
Memory: 2.16
1.2V HT: 1.24
NB: 1.34
SB: 1.52
CPU VTT: 1.36
DDR Termination: 1.07
3.3V: 3.16
5V: 4.83
12V: 11.58
BIOS TEMP READINGS:
CPU: 30
M/B: 37
OPT1 (NB): 47
OPT2: (SB): 52
OPT1,2 are sensors that came with the motherboard that I put on the north and south bridges myself, so their accuracy is probably not very high.
That's all the info I have, I'm gonna post some questions I have in a reply.
Tuniq Tower 120
Antec 900 Case
IDLE temps are:
SYSTEM CLOCKS:
FSB (QDR): 1333
MEM (DDR): 667
OVERCLOCKING:
Multi: 9
CMD: AUTO
LDT Frequency: 5x
OVER VOLTAGE:
Vcore: 1.28125
Mem: 2.1
1.2v ht: 1.2
NB core: AUTO
SB core: AUTO
CPU vtt: AUTO
Nvidia GPU Ex: AUTO
Vcore: 1.24
Memory: 2.16
1.2V HT: 1.24
NB: 1.34
SB: 1.52
CPU VTT: 1.36
3.3V: 3.16
5V: 4.83
12V: 11.58
BIOS TEMP READINGS:
CPU: 30
M/B: 37
OPT1 (NB): 47
OPT2: (SB): 52
