Overclocking and gaming
BababooeyHTJ
So, a lot of us overclock here but for gaming is it really worth it? Do you overclock? If so what are you running?
Are there any good real life gaming benchmarks (I'm not talking about 3dmark here) at real resolutions like 1920x1200 that show much of an improvement?
I just moved from a Q9650 to an i7 860 and I'm not even sure that overclocking this chip is even worth it for a gaming rig.
when overclocking my 5850 i gained a couple FPS in crysis but any game besides crysis iv never noticed any difference.
1920x1080.
The main reason for overclocking, at least for me, is that it really helps with dips in games. I run with V-Sync and Triple Buffering, so I don't really notice any difference in average framerates.
Q9450 @ 3.6Ghz
5970 @ 900/1200
Yes, it helps, 2560x1600 is a hard resolution to power and overclocking both these components helps keep the average frame rate up and more importantly the minimum frame rate up.
The upcoming Starcraft 2 RTS scales really nicely with CPU speed.
CPU - I always overclock.
GPU - sometimes it is not worth the trouble. Right now I only run an overclock for games I can't max, like BC2 to get extra performance. I usually don't run a 24/7 overclock on my GPU anymore.
Cpu - because 3.0ghz is better than 2.4ghz
GPU meh not really. with my GTX275 it plays everything I want.
Ok, I was just playing around with BF BC2 which is known to be a pretty cpu intensive game and SS HD TFE which is pretty system intensive as well and I noticed no difference between stock speeds and 3.8ghz with my GTX280 SSC. Not that I recorded framerates but I had fraps running and just didn't see a noticeable difference.
I prefer absolute stability to speed these days. If it means my gaming experience is a tad sub-par, I'd rather drop a couple settings than overclock.
Overclocking's a young man's game, anyway.
I don't know man.. Every i7 out there will give you an easy 20%+ clock with modest cooling. It's not really a gamble or a game imho. It's not like we can't check temps right? Although, with how Turbo mode works now, I guess I can't argue if anybody insists on leaving their CPU down-clocked.
I'm starting to agree with this.
How do you determine stability? I've seen prime and linpack "stable" overclocks cause artifacting or crash to desktops or data corruption (a major no no). What if everything is stable now but a year down the road you see some mild degradation (like what happened to my P45) and don't notice until the data corruption sets in? Now the MCH is on the cpu so it could be the board or cpu now. Every time that a bug or oddity in a game or driver pops up you wonder, could it be my overclock? Is it really worth it for gains that might not even be noticeable?
I personally run a 24 hour OCCT and Furmark testing that same time. I've yet to have a PC that's passed such heavy testing actually degrade, artifact, CTD, BSOD, or corrupted data in the past three years as a direct or indirect consequence of overclocking. In addition, having a quality PSU does reduce the chances of poor power being delivered to a highly OC'd setup.
Yes, Yes, E6400 OC'd at 3.2GHz.
Yes:
http://hardocp.com/article/2009/05/19/real_world_gameplay_cpu_scaling/
Basically some games do and some games don't benefit from a highly OC"d CPU at 2560x1600 depending on the CPU.
problmslver88 said:
Now, let's talk about game performance and tweaking. DO NOT OVERCLOCK YOUR COMPUTER! That is the DUMBEST thing I've ever heard any body do!
People think that overclocking your computer, you can turn a dual-core into either a tri-core processor or equate it to a quad-core. And that is a myth!
Also don't forget that when you overclock, the extreme temperatures produced may very well cause the computer to spontaneously combust all together.:cool:
Where's that quote from?
EDIT: Nevermind, I saw the video...what a jackass.
Nah, it's not really a gamble. Even the stock cooler's more than capable of keeping the i7 cool with a modest overclock, but I just don't see the point. The i7's already insanely fast. Sure, 3.2 GHz is faster than 2.66 GHz, but does that really translate into a much better gaming experience? Probably not. There'd be an improvement, yeah, but not a substantial one in most cases.
Even if I had a really kickass $70+ HSF, I'd still keep it clocked right where it's at. It's serving me well right where it's at, and I don't intend to fuck too much with it.
That extra one frame per second in UT3 at over 100 FPS is going to translate into a massively better gaming experience, yeah. I can't believe I haven't overclocked yet!
I do it because I always have the urge to get a little more performance out even if I don't notice it, but if I see any sign of instability I usually back it down quite a bit because it fucking sucks to have a game die on you in the middle of an awesome cutscene.
It helps me some,things seem smoother.I usually run at 3.3ghz but,have a profile saved in AOD thats steps up to 3.6ghz.It just seems better.
I find I get rewarded constantly for having higher clocks. I do a lot of media and graphic related editing though, among other geeky things. There are plenty of applications that scale linearly in performance with CPU speed. In regards to gaming, why not figure out for yourself. Both performance and stability are measurable.
I completely respect those who value stability over all else, but why should I automatically assume my i920 is only stable at 2.66 Ghz? I prefer to figure out myself the performance capabilities and stability issues of anything I buy.
But then the increase in min frame rate from 10 to 30 in DoW2 is relevant, no?
i am so glad you dont. would hate to read your lovely post begging for help then crying when after half dozen people try to help you still dont get it and spout off some stupid sarcastic shit like you just did.
i run my system with a solid overclock 24/7 cpu and gpu core/memory. i use aftermarket coolers on everything. overclocking and PC hardware is a hobby. i love to do it. once my system is tweaked it causes me no more hassle then non overclocked system. overclocking provides more bang for the buck and a hobby. when done right it causes no negative side effects.
little do you know, we are the ones laughing at you......you either failed to OC before or lack the knowledge to do so. that is why you mock it.
:rolleyes: The same way that your post sounds?
Well good for you. How long has this system been running overclocked? How long did it take for you to prove this stability? Even 12+ hours of prime, a bunch of linpack, etc can still have issues a couple of months down the road. Did you fold for a couple of weeks? A month or so with no odd stuff in event viewer?
Overclocking is a hobby and can be fun, that I agree with but don't flame other people with a different point of view.
Thats bs and you know it. Shit happens. If you tell me that you have never killed or degraded any hardware due to overclocking you either, haven't overclocked too many systems, go for very mild overclocks which kind of defeats the purpose imo, are very lucky, or full of sh**. Aside from the compromised stability the extra heat, power consumption, and reduced lifetime of your hardware aren't downsides?
The only thing anyone is laughing at is the way that you come off in that post.
I'm not bashing overclocking. It feels odd not having my rig overclocked now. I know where it needs to be for a decent stable oc but I'm just not so sure that it's worth it any more.
No, I've been on the edge before. Had a super-elaborate watercooling setup on my old Opteron rig (Thermochill HE120.3, a pair of Laing D5s and Cathar's one-of-a-kind Storm G5 which set me back a couple hundred bucks). Overclocked pretty damn high during the cooler months. I don't seem to recall making any threads asking for overclocking assistance back then (search for one -- you won't find it). Hell, I designed my own block -- a very high-density pin grid arrangement -- but with my living expenses at the time, I couldn't really afford to get it machined.
Did I get a massive benefit from it all of it? Unfortunately, no. I spent a lot of time, energy and money screwing around with things instead of playing games. I ditched the watercooling and put the stock HSF back on, put the Opty back at stock and found that my gaming experience hadn't been negatively impacted.
Your mileage may vary, but for me, it was a such a pointless endeavor. Fun for a while, sure, but were there real benefits? Not really.
I wouldn't be surprised if most people who overclock don't change the voltage at all, or by just 0.1 or 0.2V. You're not going to kill a chip by giving it 0.2V more and bringing it up to the point of instability at that voltage. At the moment my i7 is only OC'd to 3GHz, but it's been severely undervolted.
I've seen claims like this but I have never once seen a screenshot of 20 (preferably more) runs of linx with cpu-z to show voltage. You do realize if you are running loadline that it's not undervolted, right?
I've never killed a cpu but a northbridge thats a different story.
loadline?
EDIT:
Bear in mind that according to the BIOS, 1.28V is stock.
I don't know about him but I have 3 Q6600s which have been overclocked from day 1 and I've had no problem with them. By the way, day 1 was well over 2 years ago for all three systems. They've also been running 100% 24/7 since then. Considering I have to have absolute stability for F@H purposes (besides my own peace of mind as well as my data's peace of mind) I make damn sure everything is rock solid stable. I run multiple stress testing programs simultaneously to max out basically everything in the system to ensure that super heavy loads on the system do not cause instability of any type.
Overclocking does help with gaming. I'd hate to see how some games would perform with my Q6600 running stock speeds. I also have the video card overclocked a bit from the factory overclocked speeds as I need it. An 8800GT isn't exactly the best card to be running 1920x1200 but I can't stand running games at anything other than the native resolution of the monitor and there is no way in hell I'm going to waste money on a lower resolution monitor even if I had the money to spare.
I burned out my E8600 running at 4.0ghz / 1.3625v / 65C load temps for a year. Was rock solid the whole time and started bluescreening one day (when Borderlands came out) Either the chip burned out or the mobo, but ultimately I had to downclock to stock to stabilize it. Then a few weeks later it wouldn't run stable even at stock speeds.
The only game I noticed a benefit in overclocking that chip was GTA IV. Now with my i7, GTA IV runs smooth as butter at stock speeds... I guess I'm going to be a bit more cautious this time. I don't really want to burn my computer out just to get a bit of an ego boost and a dubious benefit in the games I play.
I've been overclocking for ages... and honestly I never really saw much of a gain. Even running an E6300 at 3.33ghz. It's fun to do, but probably not worth it in the end, at least if you don't plan on replacing your CPU every year or so (which I have been doing, but don't really want to do anymore)
I don't. The reason i get the fastest i can afford is so i wouldn't have to.
The few FPS i gain from overclocking isn't worth the shorter CPU lifetime. I also live in the tropics so heat is very much an issue here, i'll need to get a fancy HSF just to match what your stock temps.
Also, to help with my upgrades i sell my old gear. No one in their right mind will buy an overclocked CPU. Same goes for the GPU.
My friends overclocks their rigs to the hilt. All that time, expense, research, just to gain a few FPS. Constantly watching their temps like a hawk (As i've said, we live in a very hot place) Not worth it IMO, i just want to play without worrying about my temps and the voided warranty.
You broke your chip because you were running at 1.3625v. :p I definitely see a difference between 3ghz and 4ghz on my chip.
Just a crazy statement, although I'm not saying you didn't feel that way....play BC2 with and without overclocks, or for that matter, w/ and without a quad and you'll see a diff.
I have opposite experience with E6750 and Radeon 5870. At CPU stock speeds Panama Canal is barely playable. I overclocked to 3.2 and it is now smooth as butter.
So, YES, overclock helps.
Cheers,
Alexei
The way I look at it is unless you plan to keep your computer all of your life then why not overclock it? Even if you do shorten it's life by whatever amount, by the time it kicks the bucket it will well be after you've hopefully already traded out for newer tech (provided you do it responsibly). I7's are god now just like P4C's were 5 years ago. And the trend goes on. Most of us will be wanting to upgrade every couple years minimum, even those that would wait longer hey it's all good, but a lifetime? Ya right :D
Although I'll say if you don't use your chip to it's fullest potential at stock speeds then there's absolutely no reason for you to overclock it. In that case you already own a corvette that you only drive through the neighborhood streets. :)
I imagine the day that a bluray encode takes as long as an MP3 encode on a single chip. And from the looks of things it's not THAT far off. :)
CPU has been OCed to 3.0 Ghz for about 4 years now, still running strong. (Tops out at 3.25ish Ghz but I like to keep it on a safe side)
GPU has also been OCed for all of it's life. It died after 3 years and EVGA replaced it under warranty. New GPU is running strong at the same clocks.
As far as I'm concerned, free FPS. It does help a lot in BC2, specially the CPU OC.
Well a year ago, everyone said that 1.3625v is the safe limit for that chip, and you shouldn't go higher 24/7 for thermal migration yadda yadda. In fact 1.3625 is listed on intel's spec (on Newegg.com) for the chip as a tolerable operating voltage. Maybe, the upper limit, but yeah. I certainly never exceeded 1.3625 as my P45 DS3R board had considerable vdroop... but I still fried my chip.
So now I have this nice i7. Now everyone says 1.3v is safe. But if I run 3.8ghz at 1.3v for a year, will I cook this one? I don't know and I don't want to find out. This thing is already screaming fast, and how do you really know that what people say is safe is actually safe?
Yeah it is active, notice how your vcore is higher under load than while idle. Still impressive though, nice chip.
Yes...so? That's what I want it to do. What's the point of running the same voltage load and idle when clearly you could have a lower idle voltage and save more power? In any case, my new load voltage is lower than the stock idle voltage. So I'm not sure what you're talking about.
