Has anyone tried to order a copy of Vista 64 from MS (http://www.microsoft.com/windowsvista/1033/ordermedia/default.mspx) using Vista 32 purchased from a University?
Considering this might possibly be the most asked question, yeah people have tried it.Anyone tried that?
Yeah i asked that like I never read that on here beforeConsidering this might possibly be the most asked question, yeah people have tried it.
I ordered a 64-bit DVD from the website and they sent it to me....I bought my Vista Business from school for $10.
Man, I hope it works. I have one ready for pickup at the bookstore right now
Found this: "Academic licenses are only sold as Retail licenses anyway, there are no Academic OEM licenses."
http://forums.whirlpool.net.au/forum-replies-archive.cfm/934390.html
and this: http://forums.anandtech.com/messageview.aspx?catid=34&threadid=2142090&enterthread=y
Academic licenses work. I got my Vista x64 SP1 DVD in the mail just recently. My school only had 32-bit DVDs, so I had to resort to this option (also, I wanted SP1 integrated on the disc itself).
Now I'm worried. I guess if it doesn't work, I'll leave it 32bit on my old setup and go buy a 64 Luckily, it's only $10.
I'm struggling to understand what you are trying to say here. when you say "will work" what do you mean?So, all this either means that:
A. Ultimate keys, no matter where from, will work with 32 and 64. Business/Enterprise will not (if from academia).
or
B. Ultimate won't work either (cause it only gave me the 32bit purchase link, not the 64. however, it said 64 was included with Ultimate edition. So, maybe they think I have it already or maybe it won't work. I don't know.)
An OEM version contains only one DVD, and the key only works on that one, so you choose whether you want 32-bit or 64-bit in advance..
That's not the experience of the many, many people who have reported that they've tried using their '32-bit OEM key' with a 64-bit install disk and found that it works just fine!
With OEM Vista you only get a license which covers one install or the other. That doesn't mean that the key won't actually work with the other.
But if it's an OEM licensing allowable range it doesn't somehow be all "Oh! Hang on a minute! This is OEM so which disk is being used and which disk did the bloke buy?" How the hell could it? Run off and check the sales invoice, maybe?
Is there really a need for the "liar" comment? If it didn't work for you then it didn't work for you, but bear in mind that there are other possibilities here. If you used an OEM Home Premium or Ultimate key with a 64-bit install disk made from the image for Volume Licensing Vista Business, for example, it wouldn't work. Can't work, because that image isn't a complete Vista install disk image. On the other hand there shouldn't be a problem with using Volume licensing Vista Enterprose image or media, since that contains all the stuff necessary for Vista Home Premium and Vista Ultimate.I tried and it didn't work for me. Now I'm not saying that everyone posting on the internet is a liar... oh wait, I am
Simple, no?
If it can have ranges for things like Upgrade or Full install, and OEM or retail, it can also have ranges for 32-bit and 64-bit. Obviously it knows which media is inserted, because that's what you're installing from.
There are actually more ranges than the ones you mention. Corporate/volume licenses also work slightly differently (some won't require activation for example, and OEM is tied to your computer ID and can only be activated once, while a retail can be installed various times before you run out of activations and need to call in for reactivating your copy).
As mentioned above, Volume Licensing is a whole different deal.
OEM installs, just like Retail installs, can be run out and activated as many times as the user wants! Automatic online activation will generally fail if the subsequent install is run out less than a set period of time after the initial install, but a toll-free call the the Activation Center soon fixes that and gets you manually activated. Retail License Vista installs can easily enough fail automatic activation too, and necessitate a call to Call Center to get the activation completed. There is no such thing as "run out of activations".
Yes, I think there is.
I think a lot of people on the internet these days are just talking crap.
Back on topic. Quite a lot of people have downloaded an ISO off the net for their 64-bit installation media. Some of them downloaded cracked/pre-activated images. I've read one story where the guy tried to enter his key (Home Premium), it wasn't accepted, and he continued without a key... and when the installation was complete, he found that it was already activated (as Ultimate no less).
Do you count such cases as working?
There are, basically, two scenarios which 'OEM Windows' covers:And as mentioned above, there are also various flavours of OEM licenses.
Yes there is such a thing. You can activate your copy a certain number of times (within a certain time period). For OEMs this is generally 1. For retail versions it varies.
Once you ran out, you can't activate, which is why you have to call in. The activation center will then RESET your activation counter, so you can activate again. So yes, you can indeed run out. Also, it is possible that the activation center denies your request for renewal of your activations. And then you've run out period.
Whilst I completely agree that a lot of people posting on the internet talk utter crap, I don't agree that the fact warrants calling people "liars".
Doing that is a gross insult, and doing it on the internet is, in my opinion, somewhat of an act of cowardice. That said face to face in a pub would be "Step outside and let's settle this!" material, and hiding behind anonymity on the internet to say it is rather weak.
Having to activate manually isn't a "Can't activate" scenario. It's a "Have to ring to activate" scenario. Goodness me, I've seen other software products where telephone activation was the only option made available, in times gone by! 'Activation counter' only relates to automatic activation. Of course the counter gets reset in manual activation. The 'automatic activation' facility isn't and can't be foolproof, and if it fails in circumstances where a valid install needs to be activation then that's why the telephone backup system is in place.
Those who know me from when I was around here previously know that not much upsets me. That particular word, though, is one I despise. It's too much of a direct attack upon a person's honesty and integrity, even in the guise of jocularity.Then again, you seem overly sensitive to this issue. Hmmm, I wonder...
huh?You say tomato, I say tomato.
huh?
After a lecture about how people who continue to say stuff after it's been shown to be incorrect we get the "tom-ah-toh, tom-ay-toh' line?
"Can't activate" means "can't activate". It doesn't mean "can only activate the other way!"
No, not at all.That one seemed to go way over your head.
There are. Activation can be achieved either way.What you're saying is only different from what I'm saying in the sense that you assume that there are multiple ways to activate a copy of Windows, namely automatic and manual.
Effectively, there is. Same thing happens irrespective of whether you get the activation code generated and entered automatically or manually. An activation code transforms the Windows installation from unactivated to activated status.I assume that there is only one way a copy can be activated.
Further instructions, eh?On failure, you are redirected to a call center employee for further instructions.
Amen to that. I kinda thought it's what I said to start withOn the whole it doesn't really matter, bottom line is that you need to call in if you can't activate online.
Dance around the description of it all you like but I certainly don't need "instructions". Done it all too many times and know the procedures inside out. When I call in to correct the automatic activation error all I need is the activation code which activates the install and resets the error flag.
The most recent time I did it was to address a situation whereby the 'automated' process erroneously spat up a "Key already in use" error. 'Erroneously' because the key was already in use on the machine I was activating. Gotta love those 'automated' procedures, don't you? They stuff up more often than they work.
Of course I adopt a 'user' perspective. The object of the exercise isn't to achieve successful completion of the automated procedure. Couldn't care less what 'procedure' is followed. The object of the exercise is to get the install activated!
I did the same thing, it worked perfectly.
fuck it, here's a new post. that post was getting too long.
I'm going to test the installation of the 64bit media with my Ultimate key.
However, I don't have a 64bit system (yet), so it probably won't even let me get far enough to see if the key is valid. (or maybe it will- who knows. I've never installed vista)
a;slfdj;lsakjfd;lksajfd;laksjd;flajd;lfksadj;j;lksafj
I doubt you'll get far enough to input a key anyway, unless you have an x64 compatible processor. Nice Family Guy themed sig, though.
Simply put, every key is usable for both x86 AND x64. Once you have a system that is capable to utilize x64, you may choose to use the x64 version freely.
Alternative Versions. The software may include more than one version, such as 32-bit and 64-bit. You may use only one version at one time.
That would be correct. Vista's EULA supports that all of the way...
