Having a spot of bother...
Running latest version but am unable now to delete folders or rename them. Permissions are set to 777 and haven't been altered. I have a folder with movies on a pool and even when login in directly on to the server the folder is empty while from windows I can see several movies. Also I tried to create an new folder but it doesn't let me rename it. It always says permissions not set for guest access but they are set! Never had this problem before and am out of ideas so plz need some help!
ty
Before the latest update I could delete and create from my Win7 PC, now I can't do anything anymore so could use some help...any1 ??? Do I export my 2 pools and reinstall Open Indiana + Napp-it?? I really tried everything else....
Reboot Windows and OI to be sure that not a cached view or open file is your only problem.
It only started today.... and both PC and server have been rebooted several times today!
Could it be that something changed during the last upgrade to 0.8h ?
I can create a folder on my server but can't modify or delete it. When I try to login directly onto OI using IPMI the folder seems empty allthough several movies are in the folder and can be seen from Win7, When I logon using FTP the newly created folders are not shown!
I don't know what went wrong..permissions are set to 777+ and SMB had full access with guest enabled. And most of all nothing has been changed!
Could I try to export my 2 pools and reinstall everything?
EDIT : Just realised that I don't have any problems in my 1st pool and ZFS folder but only on my second Pool and ZFS folder. I also can create and change in the root of the ZFS folder but not inside a folder!! Bizar!
napp-it does not change os behaviours and there is no change in 0.8h that may affect this. If you have problems you may have several shares with same names or a permission problem (777+ indicates, that there are ACL's, try to reset recursively) or a ZFS property like read only.
You may try to reinstall OS and import pools but because most settings are pool settings, this may not help.
These settings are only defaults when creating new files and folders.
Your problem may be permissions on existing files and folders.
i would try
- change owner recursively to root example chown -r root root /Media
- change ACL or permissions recursively (chmod -r 777 /Media) or via ACL extension
Sorry but I'm not that smart with those commands...so if I was to export both Pools and reinstall OI+Napp-it and reimport the pools would that solve the problem?
no, permissions are kept (stored in pool)
try: napp-it menu zfs folder - acl extension
select folder and reset acl of folders
or enter these commands in napp-it command window (below logout);
chown -R root root /Qmedia/Media (your folder like/pool/zfs, to reset all file owners)
chmod -R 777 /Qmedia/Media (reset all permissions to full for everyone)
or login as root from Windows and reset permissions recursively (not possible with any Windows/ Solaris config)
^ try chown -R root:root /Qmedia1/Media1
Keep in mind that only root will be able to access the share until chmod is executed.
Applied both commands( chown -R root:root /Qmedia1/Media1 and chmod -R 777 /Qmedia1/Media1) but when I check Media1 folder ownership is still stuck to S-1-5-21-3401625081-2534525586-2340204286-1000 and cannot delete or change anything...am really at a loss here!
Thanks for the response, will follow your advice when I get back from work this evening!
Worst case if I don't find a sollution would someone of you guys be willing to fix it login in with teamviewer?
Ty
If you create a user called paul as suggested don't forget to enable it with smb. On a terminal on the server, as root, issue the command:
# smbadm enable-user paul <ENTER>
then,
# passwd paul <ENTER>
After setting paul's password chown paul /QMEDIA1/MEDIA1, and chmod 777 /QMEDIA1/MEDIA1.
These steps are only needed if you do not use napp-it.
Reset owner and permissions with
/usr/bin/chmod -R 777 /Qmedia1/Media1
optionally as root via putty or at local console after su
may help and is needed only when permissions are totally wrong like 000
Usually its a:
1. Create a user with menu user example paul
2. Goto napp-it menu ZFS folder - acl extension - ACL on folders
- select dataset Qmedia/Media1
3. Select reset ACL in the bottom of this page with option modify on folders recursive
Result: everyone=modify, root = full permission on all folders
4. select option: ++ add local user, select paul with full permissions
5. remove everyone@ ACL to allow only root and paul
6. share this dataset with guest disabled, login as user paul.
From Windows permissions, you should see only two users Root (Adminstrator) and paul, both with full permissions
Reset permissions recursively is not really needed because you have full permissions on the shared parent folder but
this seems to be a character set problem of file names.
This is one of the remaining problems when using a NAS between Web (napp-it), Solaris, Linux
Apple and Windows - especially when using scripts. There is only one rule about filenames if you want to avoid problems:
No problem with 127 bit ASCII characters
Often a problem with other characters -avoid-
Always a problem with /\:?' -never use-
Hey liam137,
Thanks for checking back on this. Unfortunately, I could not make any progress as I didn't get back my mobo yet. Apparently, they've sent it in to the supplier in the Netherlands (I'm from Europe) to have it "repaired"... I don't know what to expect... maybe a plant in the middle of nowhere with lots of people re-soldering mobo's...Well, I will be selling it on ebay anyway when it gets back, as I decided that I want to use SAS as well, and therefore I ordered a Supermicro X8SI6-F. That will give me 8 additional SAS ports to the 8 ports on the LSI 9211-8i card. So I have ordered the X8SI6-F, but it will not be delivered before May 11th.
BTW the LSI card has been exchanged in 3 days, now waiting on my desk to be flashed again with the IT firmware. Also, did you see there's a new version P13?
I took out every single drive of my setup (7 Samsung 1 TB) and had them tested in another computer with the Samsung (Seagate really) testing tool. I also took the long tests, looked at SMART data... NOTHING. Since it affected over time all my disks in a rather random sequence, I assume it has nothing to do with the disks.
I have not looked in "fmadm faulty" for PCIe errors. I have switched slots out of pure desparation, and it got a lot better (not perfect though).
How did you measure the transfer rates? I have never managed to get Bonnie running... and the dd stats were very odd, but I don't remember them by heart. NEVER that high, I would be very satisfied with this. I just remember that copying from Windows 7 onto the NAS dropped quickly down to 10 MB/s and stayed there or even below it. It took me AGES to copy my 2+TB of data onto it...
My Setup will be
Supermicro X8SI6-F mobo with LSI2008 SAS-Ctrl for SAS Drives
Xeon L3426 (low power consumption)
12 GB of RAM, maybe upgrading to 24 once everything works as expected
LSI 9211-8i for SATA-Drives
7 x 1TB Samsung SATA
I did not quite understand what you mean by "phase" 10, 11, 12? Also I did not understand exactly what you mean with the multipathing? Can you please elaborate?
As for the Support question, I would never ask Oracle for support. This entire thing is pretty specific to home NAS'es and I doubt they will support you with this. Especially if it does not run on SUN hardware. Best thing would be if _Gea would offer some (paid) support, but I doubt he has time for this... _Gea?
About the Power Supply, I think you should check if it has enough power to supply that many devices. Maybe try connecting less disk drives. If your power supply does not have enough power to "feed" all devices accordingly, it can create very odd behaviour.
Best regards,
Cap'
Little background again: following my reinstallation, I decided to switch from SMB to NFS file sharing protocol (I have only one Windows machine left on my home network, and wanted to make better use of my ZIL device).
Does the 4K sector and TLER issues still affect WD Green 3TB drives when using OI/ZFS ?
Does the hdd spindown work in OI ?
I do not know what you mean with the ZIL but I would say,
NFS is a very little bit faster than SMB and the best if you use it for ESXi but
I would never use it for regular filesharing with different users and platforms
unless you do not care about users but only hosts in a Unix only environment.
The easiest common use filesharing protocal between Macs, Windows and Solaris
is definitly SMB, especially with the Solaris CIFS server and NFS4 ACL. I use it even in
a mainly Mac environment.
Tler is not needed/ not suggested with ZFS
4k Sector disks are only a problem if they report 512 Byte
otherwise ZFS creates a correct aligned pool with ashift=12
I do not know about the behaviour of the new WD disks ragarding this.
Spindown is supported in OI (you may need to disable fault management (fmd) service)
What is the problem with 2tb drives that report 512b sectors? Just asking, since I have such drive but didn't "format" them with ashift=12.
Matej
Performance hit under certain circumstances.
Sectors are physically 4K long, but the HDD report them to the OS as 1/8th (512 B).
For example, consequently, the OS could ask the drive to write 512 Bytes of data, because it thinks the physical sectors on the drive are exactly that size. The drive will have to write 4k in total in fact (512 B + 3,5 KB of dummy data). If another demand arrives a little after for the same amount of writes, the drive will write again 4K.
By knowing that physical sectors are 4K long, the OS could have waited a little longer to collect more write demands up to 4K ideally, and write 4K of useful data in perfect world conditions. Regarding above-mentionned example, it could have written 4K, compared to 2x4K.
Of cause my example is a simplification, but it gives you the idea.
