RISCmaster
- Jul 11, 2005
MellowDude said:And how's your board going now you've run the 3.0 Bios for a little while RISCmaster.
How's your overclock?
I'm very happy with the 3.0 bios and I really don't think I'll update it until I have a precise need to. Personally I'm very, very happy with this board and I hope many others are aswell.
I guess the main thing to learn from any bios is the latest isn't always the best.
** BEST RAM (MEMORY) FOR MSI K8N NEO4 PLATINUM/SLI **
I will be posting my results very soon here and my website with pictures. I am still experimenting with it.
I will make a suggestion to you thou don't mind. I see you have Geil PC3200 RAM, which is restricting your systems performance. PC3200 is perfect for normal system but I am pretty sure you did not spent $200 on this MOBO for normal results. Using the Memory Divider causes a bottleneck between RAM AND FSB, nForce systems will give you noticibly better performance when RAM and FSB speeds are in sync. You are also lucky that your Antec 380W power supply is pushing your system at these speeds. One thing is clear, your PSU is damn good.
DDR400 PC3200 is the minimum requirement for MSI K8N NEO4 PLATINUM/SLI but if you really want to unleash its performance you must have higher speed RAM. I have KINGSTON HYPERX DDR500 PC4000 which easily overclocks to DDR600 (300MHz=600MHz DDR. Speed) but I think I can have more stability if I go with even higher speed RAM.
FINAL THOUGHT:
DDR500 PC4000 SHOULD BE THE MINIMUM REQUIREMENT IF YOU PLAN ON OVER CLOCKING MSI K8N NEO4 PLATINUM/SLI. DDR600 (UNLESS YOU ARE SURE YOUR DDR500 WILL RUN AT DDR600 SPEED) IF YOU WANT TO GO INSANE. ALWAYS MAKE SURE RAM IS COMPATIBLE WITH THE MOTHERBOARD, I HAD BEST LUCK WITH KINGSTON SO FAR. Once again thanks for your advice. BIOS V3.0 ROCKS.
