***Official Doom3 Demo1 benchmark thread***
spec in sig. looks like these fit in with what others are getting. 10x7 high is a good spot.
1152x864, high = 29, 33
1152x864, medium = 33, 35.7
1024x768, high = 33.3, 37.5
1024x768, medium = 37.5, 40.6
800x600, high = 39, 45.3
1024x768, Medium - 18 FPS
Quite low eh...is what I'm using for Single Player at the moment though.
I ran at the lowest resolution with all options disabled to see how high I could get:
640x480, Low - 40FPS
Still not that high... :p
in game using FRAPs
P4 2.4c
Corsair XMS Twin-x 2x256mb 3200
Visiontek 9800 Pro @ 418.5/364.5
1024x768
Medium Detail
Timedemo 1 FPS= 33
Why the hell is this so low?
you can get a much higher number on the first run by using another parameter such as
timedemo demo1 touchFx
It doesn't seem to matter what you add.... timedemo demo1 writeConfig gave the same results.
My numbers were 30.1 for the first run then 33.0, now it's 32.5 for the first then back to 33.0. It's less than a 2% difference, but every run after the second will be +/- 0.1 fps.
I also tried unpacking the .pk4 files, but still get 32.5 on the first run with the extra parameter. Very strange.
Ian G
Just picked up Doom3 from WalMart (plenty of copies at $49.88, hard to beat) and finished my system's Doom 3 benchmarks. Here they are for reference...
Asus A7N8X-E Deluxe nForce2 motherboard
AMD Athlon 2500+ at 3200+ speed, 1.7v
1GB PC3200 Corsair DDR memory (dual channel)
PixelView GeForce FX 5600 with 256MB DDR memory
nVidia 61.77 drivers, Second monitor disabled
I took benchmarks by going to console and typing timedemo demo1. Here are the results before and after config file optimizations (see below)...
Code:
Resolution           No Opts.    1st Pass w/ Opts  2nd Pass w/ Opts
 640x480,0xAF,Low      26.8           46.7              50.7
 800x600,0xAF,Med      27.4           35.2              37.4
 800x600,0xAF,Hi       24.9           30.1              32.7
 800x600,8xAF,Hi                      26.7              28.6
1024x768,0xAF,Med      19.1           24.3              25.1
1024x768,0xAF,Hi       17.9           21.3              22.4
1024x768,8xAF,Hi                      18.7              19.5
Here are the optimizations I used... modify the DoomConfig.cfg file in the Doom3/base directory:
Code:
seta image_useCache "1"       //set to 0 by default
seta image_cacheMegs "256"    //Set this to 1/4th your system memory
seta image_cacheMinK "20480"  //Must be set or turning useCache to 1 will crash game
All three must be set. This caches texture information and causes a HUGE performance increase (smoothness, average FPS), especially in lower resolutions... see the 20 FPS improvement at 640x480!
DooM 3 demo1 settings:
1280x1024, high quality, 2x AF
nVidia trilinear and anisotropic optimizations OFF
cache ON
2nd and 3rd run average = 69.8fps
(1st run = 57.5fps)
2.6c @ 3.25
1024Mb PC4200
6800U at stock (425/1100)
1024x768 - 0xAA - 75.6
1024x768 - 2xAA - 73.8
1024x768 - 4xAA - 66.0
1280*1024 - 0xAA - 72.0
1280*1024 - 2xAA - 65.4
1280*1024 - 4xAA - 52.6
1600*1200 - 0xAA - 63.8
1600*1200 - 2xAA - 55.0
1600*1200 - 4xAA - 41.3
Ok, finally figured out why benchmark was fluctuating so much.. Had to go to the nvidia control panel and set monitor refresh rates from forced to application preference. FPS is now constant 90fps 1024*768 high quality 8AF, 00AA. I mostly play DM, and the video lags a bit with more than 8 players online so that is what I run the game at.
1024*768 8AF, 0AA, High Quality, nvidia CP image setting set to high quality, 90.0 FPS 2nd and 3rd run.
At 1280*1024, high quality, 8AF, I get 77fps
Arseface said:
2.6c @ 3.25
1024Mb PC4200
Seems a little low for your system.. Read my above post and see if it changes anything.
1024x768 on High without AA and OCed GPU: 45.8 fps
1024x768 on High without AA and not OCed GPU: 42.5 fps
I don't get it, according to the HardOCP hardware charts I should be able to run this beast at 1600x1200.
I have a Athlon XP2800+ with a gig of memory.
I have a GeForce 6800GT at 384/1050
At 1024x768 I get 40.2 FPS on demo 1
At 1280x1024 I get 41.7 FPS on demo 1! What is up with that?
At 1600x1200 I get 37.5 FPS
However, when I go in game, 1280 and 1600 are hardly playable.
I'm running 61.77 w/ DX 9.0C. Any ideas?
UPDATE: Think I fixed it. I disabled my second display and now I'm getting 55FPS at 1024 and 45fps at 1280. I had the same problems with the NVidia demos, very weird.
mikemodano9c said:
don't get too giddy yet...
76.1 fps @ 1280X1024\Ultra High Quality\All Options On
p4 2.4 prescott @ 3.6 ghz (aerocool dp-102)
1 gigabyte kingston hyperx pc4000
abit ai7
pny geforce 6800 gt (430/1.10)
(1) wd 250 gig (1) wd 120 gig (1) seagate 80 gig
dvd burner
cd burner
etc. etc. etc...
how come i only get like 44.. this is weird. this is just with high quality at the same res
i pretty much have the exact same system, yet mine is in the low 40s
this was my old post on pg 2
12x10 high no aa 18.4 25.5
12x10 med no aa 21.7 26.5
10x7 high no aa 23.4 34.4
10x7 med no aa 28 36.6
10x7 med 2xaa 21 30
8x6 med no aa 32.4 43.8
8x6 ultra no aa 18.3 32.3
after config hacks vsync, triple buffer, reformat, and humus hacks got:
12x10 high no aa 48.5 no f(^%$ joke thanks guys....
tweaked my d3 beyond belief
1280x1024 high settings w/ shadows off
0xaa 0xaf
p4 2.6@3.21
1024mb ram ddr400 @ 400 (5:4)
2x wd 80gb raid 0
aiw 9800 pro @ stock speeds
::: 69.8FPS :::
no bullshit, if someone wants a fraps video ill do it, i hit 70fps in 1024, i didnt try w/ shadows but this eye candy is more than enough for me, and im getting sick performance.
Athlon 64 3200 2.0Ghz 1mb cache
MSI VIA mobo
2x512 CL2.5 4-4-7
WINXPPRO SP1
e-vga GF5900 128mb 400/850
Driver 61.76
1024x768
med 52.2
high 51.6
uhigh 48.8
1280x1024
med 34.2
AMD Athlon 1600+
MSI nForce2
768Mb ram
Radeon 9600 Pro 128mb 450/255
800x600 High, highest texture settings in ATI panel, 16x AF
32fps in timedemo1.
I've been playing single player at 1024x768 Ultra, 16x AF, seriously. Doesn't run blazing fast but its smooth for the most part. It slows down just as much as it did at 800x600 high, and its not even close to unplayable, plus looks totally rad. I never ran a timedemo for that setting though. I'm right at the end of alpha labs now and I havn't had a problem with slowness so far...
i think thats similar to wat i got with xp3200+, 9500@9700. i can play d3 1024x768 high with 9500. yay.
Something is borked. Your framerate should MUCH higher. Did you install your motherboard drivers (4in1 Hyperion Drivers)?
