unimatrixzer0 said:Is Dell planning on a 2408/2409 yet? Or is the 2407 new for this year?
kimnkk said:I t hink i've read the whole thread and i can't find any pictures of an xbox 360 running at 1080i through component. Any out there?![]()
Bo_Fox said:60 Hz refresh rate SUCKS, man!!! It sucks wayyyy down to the devilish hell, to the devil's whores, man! It just suuuuuuuuuuuuuuuuucks!!!!!!!!!!!!!
chew63 said:refresh rate for LCDs doesn't really matter.
kimnkk said:Well, the banding problem seems to be because the images and programs played a major part.
http://members.iinet.com.au/~kimnkk/Gradient Tests/
Try the .jpg and you will see some light banding, but if you try the .png and .psd (if you have photoshop) there will be absolutely no banding. This is on the A02. There probably will be even no banding on the .jpg for the A03! At least we know why some people report banding on the A02 while others say it is perfect.
damp81 said:If im looking at a 1080 movie, will it stretch it out to 1200 or will it keep the aspect as it should be?
RadXge said:2405FPW vs 2407WFP A03
- 2407 has better viewing angles
- 2407 has better respond time
- 2407 has much less input lag
- 2407 looks nicer (but this is a matter of taste)
- 2407 has HDCP with 480p and 720p while 2405 is not HDCP
- 2407 has generally better uniformity (but this varies by unit)
- 2407 components input is defective at 720p and 1080i. This was not a problem with 2405
Therefore, for PC gaming the 2407 is a significant improvement over the 2405.
For XBOX 360 and PS3 gaming, the 2407 is a step backward compared to its predecessor.
unimatrixzer0 said:How about for just hooking up and hd-dvd player or an hd cable box to the components?
RadXge said:I am not suggesting to replace the 2405 by the 2407 but...
1) The 2407WFP Respond time IS better in real life. There is the proof:
http://www.tftcentral.co.uk/articles/dell_2xx7wfp.htm
2) Hum... 35ms vs 55ms is still an interesting improvement. I personally felt the input lag wit the 2405 but not with with the 2407.
I suggest the following article for more details regarding the input lag.
http://www.behardware.com/articles/632-1/lcds-images-delayed-compared-to-crts-yes.html
In short, using vertical sync and/or a wireless mouse also add input lag.
3) The 2407 A03 revision does not display banding. Dell first sent me the A02 revision and it had vertical banding. This has been validated on the Dell forum even if Dell does not acknowledge it.
So saying that "the color banding on the 2047 is a side-effect of making the input lag less severe" is BS.
Therefore, the 2407 A03 represents a significant improvement IF you do not need the components input.
Another weakness of the 2407 is that 1600*1200 is stretched by the monitor unless a NVIDIA video card is used. This is annoying for all the ATI users...
Bo_Fox said:Oh yeah, but component sucks on 2407's while it's perfect on 2405's...
I wonder why??? Maybe it's to keep people from using component to bypass HDCP?? Maybe it's a requirement that Dell had to implement (by impairing the component input quality) before including HDCP on 2407's. Otherwise, Dell should have fixed it by revision A01 or A02!
A discriminating mind can figure out a lot of things on its own.
Bo_Fox said:In Rev. A03, it is crippled in Desktop mode, so that's why color banding is no longer seen. However, there is still severe banding seen in Gaming and Movie modes (due to that Magicspeed RTC application, or in other words, Overdrive which we hate more than like).
paul_mendoza said:Can you post pics of what it looks like in 1080p vs 720p? I heard about vertical lines appearing and I wanted to see if that was a major issue. I just ordered a 2407 so I'm kind of worried about that.
