- Feb 26, 2005
The other night I OC'd my cpu by about 300-400MHz on stock voltage(mb won't let me adjust cpu voltage, but it will adjust other voltages such as NB, memory, and PCI-E). I upped memory and NB by the smallest value possible(.005V for NB iirc and something similar for NB).
I ran Prime95 overnight to test the OC and went to bed. About 4hrs or so later the computer shut off. When I woke up it wouldn't power on for a few mins. I unplugged the pwr cord, flipped the switch, changed walls sockets, and it finally turned on. After a few minutes I hear a fizzling sound(not like a capacitor popping though). Computer is running fine now but I don't think I'll be doing much overclocking anytime soon.
From these pics it looks like I fried an inductor. The weird thing is the voltages in AMD Overdrive have a red background now(don't remember that). On another note, there were also multiple power outages last weekend due to rain. Not sure if that might've had an effect on it.
What are your guy's opinions on this, keep using it til it dies or replace the inductor just to be safe? I found the product info so I could probably order one online to replace it.
Inductor in the middle(black box thing)
[Edit:] System is in sig(minus one 5770)
