Can my PC? Nope. heh.gurgle said:can the 360 play this game at 1680x1050? Nope.
aces155 said:From what I hear I am glad I got a 1280x1024 native rez LCD monitor.
fx-60, asus a8n32-sli deluxe, sli PNY 7800GTX 256, and 4gigs of Corsair 3500LL pro.
2 more weeks until my phase change system gets here for my proc. I cannot wait to see how good this game looks! WOOT!
Explain that one Mr. Big shot.skidmarq said:You know that you'll get better gaming performance with only 2Gb of that memory?
theNoid said:Hmm this is really beginning to PISS me off. I thought I had the settings good, but now when im out in the middle of the forrest I CANNOT even play with grass on.
2600+
1gb
6800 GT OC
On MEDIUM settings .... THIS IS REDICULOUS!!!!!!!!!!!!!!!!!!!!!!!!!
sakurakana1003 said:Don't feel bad, I can't play with any grass on either.
Stu55 said:Even with a 7800 GTX and an X2 cpu?!?!
Andrmgic said:I play with grass on, but I'm not trying to play at my lcd's native res with all of the settings maxed, and I'm not a framerate whore hehe.
I play at 1280x720, scaled to aspect ratio
with grass sliders all the way up and trees and actors 3/4 of the way up with vsync disabled and hdr on.
I get 20-35 fps running around outside, occasional dips below that, but I get 40-70 indoors almost constantly.
The game runs well for what it is trying to do, and a hell of a lot better than Morrowind in terms of performance. That said, it isn't the world's most efficient engine by any stretch of the imagination.
sakurakana1003 said:Yup, at 1680x1050 or 1920x1200, doesn't make much of a difference which. Neither will run above 30fps if I turn on grass.
KSNIPPY said:my 7800gt runs it decently, but not as good as i was hoping for this game is mad demanding.
sakurakana1003 said:Many, including me, have thought the same thing. I really expected my 7800 to do a little better than it is doing right now. Either drivers aren't fully optimized yet (I'm running 84.25 though), or the game itself could have used more optimizations. Because honestly, the game looks great and all, but it doesn't look like it should be choking my 7800 GTX THIS MUCH.
Installed CoolBits - Changed (in Additional Direct3D Settings)
Max frames to render ahead to "0" .. it was set to "3".
All stuttering and "mouse lag" is gone. The game runs like a dream, and is amazing to play.
Colonel Sanders said:What kind of settings are you running again?
sakurakana1003 said:I actually have no idea which "level" I'm at right now since I messed aorund with the settings and changed quite a few things. But the thing is that even at 1024x768, turning on any bit of grass will slow the FPS dramatically, but I'm natively running at 1920x1200, I believe most everything is on high, no grass. Runs okay, could be better.
Colonel Sanders said:Are you using AA and/or Aniso?
NoDamage said:Looks like this might help with things, some people are reporting a good performance boost:
magnuspah said:Guys, I have noticed that when I uncheck vsync at the startup options, my frames increased by 15fps. This is of course with a dell 2405 at 65mhz with 1920x1200 resolution +HDR and forced 4X AA (control panel). I noticed that the fps seemed to be capped at 30ish in some places and go down to 20s outside with lots of npcs around. When i disable vsync, there did not seemed to be any changes in video quality but my fps are now at high 30s at the most demanding areas.
I am now satisfied. Now, if I can get myself to actually play the quests instead of roaming the streets and marvelling at the environments...
theNoid said:Its just terrible though, I really think the game is fun.. but quite honestly these video problems are making me want to fucking crack my disk and write a letter to the dev. I mean I meet the 'recommended' specs, minus my cpu a bit .. and I cannot even handle medium textures is grass off, and everything dumbed down ... WTF.
I am supposed to go dump another $1500 into my pc every time a game releases just to play it ?
sakurakana1003 said:What monitor are you using? Because with the 2405FPW driver I don't have the the option of 1280x720. 1600x900, 1680x1050 and 1920x1200 are all I have for widescreen.
