http://videocardz.com/55013/nvidia-geforce-gtx-titan-x-3dmark-performance
only 30% fast than a 980 (stock for stock). is that a bust?
I didn't see this till someone else brought it to my attention but the NVIDIA CEO quoted saying that the Titan X will be faster than their previous dual GPU card the Titan Z. If so that's insane power of 1 card.
Source
Also rumored is that the stock clock speed of the Titan X is 1390Mhz which may explain which it will be faster than the Titan Z.
while i agree that 3dmark is irrelevant, nV normally have great drivers for it..
But these are early days.. but still under 40% more performance than 980 gtx will be a fail in my book. (for the price, which i think will be close to 999$)
If i am wrong and this goes for something like 800, or performs like a champ.. well.. *droll*
So you have a better source or information in general? Youre way too optimistic.Those aren't Titan X benchmarks and it's videocardz. They're the same type of b.s. site as WCCFmakeupshittech.com. Wait for the 17th before you start spouting off nonsense.
I apply common sense unlike you. They don't have a Titan X on hand, I could go make shit up and post pretty graphs too. Nobody aside from NVIDIA and the credible reviewers (e.g. Hard|OCP) they gave samples to know the final clocks or performance of this card in games. Besides, worst case scenario if the base Titan X is 30% that puts it in line w/the previous Titan. People are expecting at best 40% increase for the R390X vs 290X which still puts it behind this thing. So again, how would this be a failure?
Considering what you just said, you dont know the final specs of the 390x cards, so the same applies to your statement.
I dont believe I said anything related to failure, so you might want to recheck my posts.
do you really think nvidia will give benchmarks? they might give specs, but i dont think they will give clocks or benchs. they will hold out to see what the 390 does. if they say our card does x, amd will say our card does x+1. its all marketing.
Called it. I knew it was 30% faster at most.
Yeah 35+% improvement at likely 1080p and likely larger boosts at higher rez, definitely in for one especially if it comes it around a grand...
I guess we will see with 4k benchmarks what kind of difference 12GB of RAM makes
Honestly if you ask me, if you are planning on getting this card for anything less than 1600p....you are definitely wasting your money.
The data from the videocardz numbers are being interpreted incorrectly.
If you compare the lower result for the GTX 980 (stock) and Titan X (stock? 1002 listed speed) the Titan X is actually ~35% faster for performance and ~40% for extreme. The previous values being listed may be mistaking absolute and relative differences. 100%/74% and 100%/71% is the relative difference not 100%-74% or 100%-71%.
Uh oh top right corner is missing a screw:
Sorry couldn't resist.
No backplate for a $1000 ++ card. nVidia so cheap, first screwing us out of 0.5gb ram, then screws and now a backplate.
A bit disappointed with a revealed performance graph. In 3D Mark it's only 26% faster than 980 and 40% than 970. Was hoping for 40%, so the 980 Ti would be 20% faster. RIght now we will propably have 980 Ti in like 10% diff, so OCed 980 will take it.
http://www.ocaholic.it/modules/news/article.php?storyid=12014
did you check the source?.. its the same videocardz performance charts mentioned one page back.. fail charts to gain some clicks..
not only are they the same graphs, looks like MorgothPI also misinterpreted them. The graphs are using the Titan X as the baseline, so you have to recalculate the percentages if you want to know how much FASTER it is than a 980. The graphs show how much SLOWER the 980 is. If you assume the 980's scores are the 100% baseline, the stock Titan x is ~35% faster in Performance and ~40% faster in extreme.
Again, that's assuming these numbers are actually accurate.
Add in these cards are conservatively clocked and you have a card that is basically 50% faster than a gtx 980. Titan X at these clocks has a 11% clock disadvantage to the gtx 980.
So add 10% these scores and you have something that is about 50% faster. If someone makes a bios mod that allows overvoltage and a waterblock, these cards are gonna fly. Ever without water, these cards should be challenging a r9 295x2 once overclocked.
I think he's thinking of the Titan Black.
The ~50% increase in transistors means next to nothing about performance, it just means that they have a 600-620mm2 GPU on their hands.
The 50% increase in actual specs is what can be used to determine performance.
That means peformance will be ~40% better than the GTX980.
Now clockspeed, the larger you make a GPU, the more variables there are with voltage and speed. You typically don't clock as high as the smaller GPUs in the family. Obviously Maxwell 2 has made some significant strides in the clockspeed department but I would expect a ~10% decrease in clocks compared to GTX980.
So 30-35% over GTX980 seems about right.
That leaves room for a GTX980Ti to be ~15% better than GTX980.
It could definitely reach up to 40-50% better in some situations but IMO, on average, it will be a bit lower than that since scaling is never 100%.
Unless there was some glaring bottleneck in GM204 that they resolved in GM200/210... But I think most of us believe that GM204 is a very well balanced GPU.
snip
Now the $629 295x2 looks like a fuckin steal when looking at that benchmark
Not really considering the state of CF support in games.
I like OC vs OC better. If this card is voltage unlocked (which I really doubt) or hard moddable I am going to be pretty excited and it could destroy most 980s (since most are voltage locked).
I would imagine the current maxwell bios editor would work. Should only take 5 minutes to mod the bios. I'll rush my chilled water system ahead of schedule and buy a 5960x if it is truely unleashed....
