BababooeyHTJ
- Jan 21, 2009
Unless the improved power phases and cooling on the GTX 690 let you overclock better.
That doesn't seem to be doing much for the non-reference cards.
Aren't the non-reference cards that are out now just reference PCBs with different coolers? I'm curious to see what cards with better power will do - like that Palit card with 8+6 power that was reviewed at 1350+. You are right, though, in that 8+8 power on this card might not translate to any additional benefits, since it is feeding two GPUs.
No way of knowing yet but theoretically they would be equal if all speeds were equal. However my guess is that the 690 will be downclocked slightly and so, as with all of these dual-GPU cards, it will probably be slightly slower than 680 SLI.
There have been a couple reviews of the Twin frozor and a few models with a reference pcb with a couple of extra phases soldered on. I've seen a few reports on OCN. They all seem to fall right in where a normal GTX680 does. These cards don't draw much I really doubt that power circuitry is the limiting factor. Not without being able to adjust the voltage, anyways.
You've got to remember that there are reviews with some reference cards hitting 1350mhz stable too, who knows how much that was stress tested. Is that even representative of what most of those Palit cards can do?
Consider GPU Boost, just like 680 SLI each GPU will operate at different voltages and frequencies independently in real time.
I don't know. I agree that power phases don't really matter much, but my take-away from the Palit review was that the extra power connections allowed the reviewer to set 150% power in Afterburner/Precision, instead of the 132% the reference cards allow - which may be the difference in overclocking. Voltage control would be nice also, if that is ever allowed.
ASUS DCII TOP for pre-order:
http://www.amazon.com/dp/B00814JQPC/?tag=nisa-20&m=ATVPDKIKX0DER
Gigabyte Windforce pre-order:
http://www.amazon.com/dp/B007ZUDOKG/?tag=nisa-20&m=ATVPDKIKX0DER
Gigabyte reference in stock May 21st:
http://www.amazon.com/dp/B007KEAGG2/?tag=nisa-20&m=ATVPDKIKX0DER
