- Oct 6, 2010
"ONE MILLION DOLLARS!!!" -Dr Evil
That would get them sued out of existence, this is a huge blow to them. Now any features they implement they have to be able to prove in a court they developed or reverse engineered completely on their own. If any of their contributors so much as glances at that leak the project is as good as dead.^ That could be a goldmine for the nouveau Linux guys.
Why? How? Unless Nouveau copies their code 1:1 then I can't see this happening. Also, Nvidia's code isn't exactly better than MESA. Intel's and AMD's open source drivers are arguably better than Nvidia's on Linux. Nvidia has really let their Linux drivers go over the past number of years. Nouveau's biggest problem isn't their code but the lack of firmware from Nvidia. Without it you can't set clock speeds or anything really. That and the lack of funding. Every month you hear about Intel and AMD hiring new people to work on open source drivers. Valve hires people to work on open source drivers. If anything the Nouveau guys can look at the source code and maybe be able to set the clock speeds of GPU's properly. Even still the Nouveau drivers are so bad that no Nvidia owner would use these other than to boot into Linux to install Nvidia binary drivers.That would get them sued out of existence, this is a huge blow to them.
Nobody is going to court for implementing a feature that's similar to Nvidia's. Firstly you need source code or hexadecimal code proof that it was stolen. Second, I really doubt anyone is going to do that. Most of Nvidia's stuff is for Nvidia stuff, so what's the point of implementing it? If anything an underground bunch of people are going to compile the code for a driver that doesn't have any mining limitations. That's the least buggiest thing one could do that doesn't require a lot of work. Anyone who tries to merge Nvidia's code with AMD or Intel drivers are going to introduce a lot of bugs that simply won't work without a lot of man power working on it. That doesn't mean AMD and Intel driver engineers won't take a peak on the code. Not the end of the world considering both AMD and Intel freely release their code for anyone including Nvidia to look at, which I'm sure they do.Now any features they implement they have to be able to prove in a court they developed or reverse engineered completely on their own. If any of their contributors so much as glances at that leak the project is as good as dead.
Opensource software development is required to keep a Clean Room approach to all features they reverse engineer for a reason, now NVidia may not necessarily go after them for implementing some features but there are big legal differences between reverse engineering something and looking at the blueprints and walking them backward. Bigger opensource projects have been shut down for less. They wouldn't need to steal the exact code, NVidia would only need to argue that there is reason to believe that they used the leaked code as a reference guide. For legitimate projects like Nouveau, this is a problem, for people who weren't concerned with the legitimacy of their projects to begin with, this only helps speed them along. But no the Nouveau guys can't look at the code.Why? How? Unless Nouveau copies their code 1:1 then I can't see this happening. Also, Nvidia's code isn't exactly better than MESA. Intel's and AMD's open source drivers are arguably better than Nvidia's on Linux. Nvidia has really let their Linux drivers go over the past number of years. Nouveau's biggest problem isn't their code but the lack of firmware from Nvidia. Without it you can't set clock speeds or anything really. That and the lack of funding. Every month you hear about Intel and AMD hiring new people to work on open source drivers. Valve hires people to work on open source drivers. If anything the Nouveau guys can look at the source code and maybe be able to set the clock speeds of GPU's properly. Even still the Nouveau drivers are so bad that no Nvidia owner would use these other than to boot into Linux to install Nvidia binary drivers.
Github maintains a list of all their takedown requests, I don't have it at the moment but I do know it exists.Got an example handy?
Github shuts down many projects that isn't related to stolen code. I know a number of Mangos projects that were shutdown not because of stolen code but because the use of this software can only be for illegal purposes. Though I'd argue a WoW emulated server is not illegal in of itself.Bigger opensource projects have been shut down for less.
The problem I see with this is that there's only so many ways to say "hello world". While I believe coding is an art, but individual lines of code aren't. Could Nvidia take Nouveau guys to court? Sure but then again nobody at Nouveau makes any money running Nouveau so this would be Nvidia flexing it's money muscle to get their way. This also doesn't help Nvidia's public imagine on their lack of open source driver support.They wouldn't need to steal the exact code, NVidia would only need to argue that there is reason to believe that they used the leaked code as a reference guide. For legitimate projects like Nouveau, this is a problem, for people who weren't concerned with the legitimacy of their projects to begin with, this only helps speed them along. But no the Nouveau guys can't look at the code.
There are two potential issues at play here and a semi-third specifically about leaks like this:Github shuts down many projects that isn't related to stolen code. I know a number of Mangos projects that were shutdown not because of stolen code but because the use of this software can only be for illegal purposes. Though I'd argue a WoW emulated server is not illegal in of itself.
I'd like to know what's a GPU manufacturer doing with anything security related? For them to get hacked means that Nvidia wasn't paying as much for their network security as they should.It can potentially be a National Security disaster if the leaked data includes export-controlled design data (iirc this is usually some gnarly floating-point or cryptography designs).
What I'm really curious about is if Nvidia will face Federal charges in such a scenario.
Having worked at some of the "big" chip manufacturers myself - export regulations for logic designs (not sure about software) are absolutely no joke and carry heavy Federal penalties.
Nouveau is a dead project as far as I'm concerned. Without anything to give it a massive boost that it needs then not even a massive leak of Nvidia's driver code is gonna fix it. For Nvidia to go after Nouveau is literally shooting themselves in their own foot.With that said, traditionally someone trying to implement a new feature in nouveau or such would follow a similar path to reverse engineer a feature. Nvidia can’t really sue them because reverse engineering isn’t necessarily illegal. Now enter the case where some “hackers” leak all the design specs and source - **any** new feature in a project like nouveau is now instantly suspect and nvidia would have a much easier time filing lawsuits - sure, they’re not slam-dunk lawsuits but still more likely to result in nvidia’s favor than in the previous situation without the leaked data. Basically this doesn’t help anyone and could in fact jeopardize entire projects like nouveau.
I don't disagree, but some environments are more susceptible to that than others. Trust and reputation are vital to distributed OSS projects such as Linux, as are thorough code review processes. Linux didn't grow to become the tremendous success that it has because of formal policies, but because of its large network of contributors from around the globe that by some small miracle have managed to work together, and in the course of so doing they've had to deal with all sorts of legal issues (copyright, patents, NDAs, etc.). So this isn't new territory, or even a big deal so far as the kernel or the userspace (Mesa 3D) drivers are concerned. No one from either team is going to risk ruining their reputation, career, or worse, just to make the Nouveau driver slightly less bad. The reward isn't there. Code also has to pass review, which in the case of the kernel is a multi-stage process. I'll add that the review process does seem much more robust against legal bugs than security ones.In regards to the clean room policies, they are great when followed but anybody who has worked in an office can tell you no matter how clear or easy the policies are there's always some jackass in the back corner who thinks they don't apply to them and that they won't have any problems.
It would be incredible if Nintendo sued Nvidia over the breach:'( The leak seems to have outed the Switch 2 specs...
Looks like Nintendo is going with the Tegra T239 which is pretty dope
There also looks to be some correspondence with Nintendo about possible PC releases
But now that it's been leaked knowing Nintendo they are probably going to cancel that.![]()
Not really there are no winners in that situation, no matter the outcome they both lose, and while they argue it out in court the rest of us lose, it would suck.It would be incredible if Nintendo sued Nvidia over the breach
adjective: incredibleNot really there are no winners in that situation, no matter the outcome they both lose, and while they argue it out in court the rest of us lose, it would suck.
I took it as 3.adjective: incredible
1.
impossible to believe.
"an almost incredible tale of triumph and tragedy"
Similar:
unbelievable
2.
difficult to believe; extraordinary.
"the noise from the crowd was incredible"
Are they going to release a new shield?:'( The leak seems to have outed the Switch 2 specs...
1.
Similar:
unbelievable
2.
Well you have to give your users access to the data somehow. How would such a system work? Users login to a virtual environment that has an encrypted connection to somewhere else? Adds latency, time and complexity.I don't see why companies don't allow hackers into false access to false data that blows up in their face. Basically making hacking not worth it, exposing hackers, locking up their equipment etc. False traps. Making hacking a particular company mostly suicide.
I also fail to see why sensitive information is not behind a wall of encryption with access only by hardware key with additional fingerprint/face etc. besides the usual password for access to the computer. Having a separate email/correspondence/internet network so internal work I would also think would be the norm. Anyways I just don't know enough about this in the end, I just wonder how in the world can Nvidia can be hacked at any significant level, source code breach etc.
Not sure what dictionary you got this from, but...adjective: incredible
1.
Similar:
unbelievable
2.
Start a new thread. That has all kinds of implications, too. No more locked bootloaders on Samsung devices?Samsung Seemingly Falls Victim to Nvidia Attackers
Lapsus$, a hacking extortion group that previously targetted Nvidia, has begun crowing about a significant Samsung data leak that it has architected...the hackers claimed they plundered about 200GB of compressed data from Samsung servers, including confidential documentation, code, and other proprietary information...more specifically, Lapsus$ claims to have its hands on Knox authentication code, biometric unlock algorithms, bootloader code for all recent Samsung devices, Trusted Applet source code, code behind online services and Samsung accounts, and much more...
https://www.tomshardware.com/news/samsung-seemingly-falls-victim-to-nvidia-attackers
Definition of incredible
lol. i believe we're all in agreement? both your definitions seem to agree with mine. sorry for the hijack.Not sure what dictionary you got this from, but...
I wonder if that's going to be more powerful than Valve's Deck?:'( The leak seems to have outed the Switch 2 specs...
They should have been doing this decades ago. If PC emulators have anything to say about Nintendo games is that there's a demand for them on PC. Good chance the amazing work of emulator authors have made Nintendo piracy super easy, and the reason why Nintendo is considering releasing their games on it. I'm just wondering what DRM they're going to use to ruin it?There also looks to be some correspondence with Nintendo about possible PC releases
I don’t know about faster, existing cellphones using the A78AE cores score around 3200 to the decks 3700 in Geekbench, but that’s using Mali and not using Ampere. But the Tegra will probably be pulling 7-15w compared to the Decks 40??I wonder if that's going to be more powerful than Valve's Deck?
Right now the Switch isn't that much better in battery life compared to the Deck. The Deck does have a slightly larger battery as well. I'm guessing Nintendo will nerf this chip like they did to the Tegra X1 but who knows. I'm thinking the battery life with be the same if not worse than the current Switch.I don’t know about faster, existing cellphones using the A78AE cores score around 3200 to the decks 3700 in Geekbench, but that’s using Mali and not using Ampere. But the Tegra will probably be pulling 7-15w compared to the Decks 40??
The battery packs aren’t even close.Right now the Switch isn't that much better in battery life compared to the Deck. The Deck does have a slightly larger battery as well. I'm guessing Nintendo will nerf this chip like they did to the Tegra X1 but who knows. I'm thinking the battery life with be the same if not worse than the current Switch.
from my reading it 3.7 v. so i think closer to 16Wh.The battery packs aren’t even close.
The Switch battery is rated at 4310 mAh which is 4.31 Wh.
The steam decks battery is rated at 40Wh it has a vastly larger battery.
I read the wrong stat when punching in the calc I read the low power state which was a 1.2v draw so thats me not knowing how to read a table. But yeah still a significantly smaller battery than the Deck.from my reading it 3.7 v. so i think closer to 16Wh.
The steam deck uses a 5,313mAh battery. It's not that much bigger.The battery packs aren’t even close.
Thank you for that.Back on topic please.
All I know of this weekends leaks are that they published NVidia’s driver certificates so malware publishers can use them to certify the installers.Thank you for that.
So I didn't see actual confirmation I trust. Did they leak what they promised? If so, how do you guys think that will effect nvidia in the future?
So much for their hacking for the people.All I know of this weekends leaks are that they published NVidia’s driver certificates so malware publishers can use them to certify the installers.
Wonder how long its going to take to get those invalidated.
The leaked certificates are already in circulation and new malware/virus variants are already popping up using them.
There is a registry tweak how to prevent Windows from validating them. Because Windows will still allow the installation of expired certs for legacy reasons.
Remember they first demanded money from Nvidia but were ignoredSo much for their hacking for the people.
They never were, they demanded money first. And “Ethical” hackers don’t go after hospitals and clinics which were their previous targets.So much for their hacking for the people.
