there will not be monitor with G-Sync with slower panel than 6.9ms for quite some time, probably none in 2014
also 60Hz monitor owners ARE NOT INTENDED TARGET GROUP for G-Sync
it is targeted at 120/144Hz freaks, not your ordinary I don't see point of 120Hz folks
monitors with G-Sync will be fewer and more expensive than 120/144Hz and definitely aimed at hard-core gamers, especially online gamers
so yes, that is a cheat
If I was there I would kindly asked them to run left monitor at 144Hz and then never get invitation to another NV event again
Eh? Putting out some questionable info here.
1st: Those tears are pretty fast for a 1/4 speed video. What makes you think the left monitor is running at 60 Hz? You have any proof or just pulling that out of your ass? If it in fact was 60 Hz, there is nothing wrong with that. 99+% of monitors out there are 60 Hz displays. NVIDIA and AMD keep pushing for 4K, which are all 60 Hz displays. My truest interest in G-Sync is paired with a 4K monitor. That would most likely get me to move away from Lightboost Surround which has a ton of flaws.
2nd: G-Sync is targeted at ALL monitors. Just because they are putting it into a very popular gaming TN panel that is easy to retrofit first, doesn't mean that is all it's targeted at. As a matter of fact, 60 Hz panels like IPS and 4K panels would benefit even more from this technology than gaming TN panels. They mentioned this in their discussion video.
3rd. There is absolutely nothing negative about this technology. It fixes or reduces three main problems inherent to all displays; tearing, stuttering and input lag. Any and all displays could use this technology. Whether you are willing to pay the extra cost for it and are willing to stick with NVIDIA is completely personal.
