nTune: yay or nay?
The Saint
Guys...
how's nTune? Anything I should be aware of or it works flawlessly ?
Any issues or systems catching fire?
:p
dont use it with DFI boards unless you want to RMA it. Aside from that I havent heard any issues.
I used it a while back on an nforce 2 motherboard. It did nothing but oc the AGP bus speed. I think it's more gimmick than an effective tool personally.
I use it to benchmark my RAM, and monitor CPU temperature. Both seem a little funky.. but as long as I stay away from the overclocking tool (or whatever it's doing) I'm fine.
I say nay. Ultimately, it doesn't seem to really DO anything. On all of my various nforce boards there are always a few things that don't read correctly (some frequencies and temps), windows overclocking is a big no-no, and the benchmarks are so ambiguous that they're worth nothing.
i've found that it's pretty much useless for anything other than monitoring your CPU/GPU temps (if you have an NVIDIA card, that is). the temperature logging is marginally useful if you're doing stress testing because you can easily see if your hard lock was caused by a heat issue or something else. other than that, not worth the hard drive space. the thing can't even report memory speeds correctly if you're using a non-standard FSB.
If you're going to OC, use ClockGen (I guess that's a nay).
