Northbridge Airflow opinion needed
BingeBoy
Just got my new board and need a opinion about my northbridge cooling.
Photo of board
http://www.flickr.com/photos/bingeboy/2310765773/
Is the cpu cooler going to work with the northbridge cooler? Its a tight fit and things are fitting I'm just wondering if there is going to be enough airflow on the northbridge. With the gpu in there too there won;t be much room for the flow.
Thoughts?
That looks like the DFI board. I have the HR-05 SLI on a different MB which is similar to what you got on your DFI. It does not have much clearance, but I don't have any problems with heat. Might be because I have the Antec 900 with tons of fans though.
I think with a front and rear case fan you should be fine. The random airflow because of the proximity to the 9700 should probably be enough. Just watch your temps I guess.
Yeah, watch them close. I realize the X38s don't run as hot as the 680is, but they run hotter than the P35s and most P35s have active cooling on the northbridge, so...
Its better than stock and you might get some air from the cpu cooler hitting it. eh, just OC the piss out of it and stick a finger down low on the NB heatsink if you can keep it there for a count of 10 you are good to go.
