Hi
I have just assembled my newly purchased Mercury S8 from Caselabs, however, the noise from the fans (2x Noctua NF-A14 FLX fans.) is killing the fun for me as there is a lot of noise - the noise is very similar to the sound coming from an air duct.
The question is what one can do in order to reduce the problem ?
My Noctua fans comes with three sets of cables which I think can reduce the fanspeed, however, I'm not to keen on this solution as I wish my fans to be able to blow as much air in and out of the case as needed - e.g. I don't wish to end up in a situation where the components don't get adequate cooling because I have chosen to install some speed reducing cables as this would defeat the point of having huge fans in the first place - right !
So, I'm thinking of going for a solution where I would reduce the noise from the airflow, by cladding (is this the right expression ?) the inside of the case with noise reducing materials - I need some recommendation from you.
To solve the problem of the fans going full revs all the time I have thought of getting a fan control, however, I would prefer something which I don't have tamper with e.g. more like something which just sits and is controlled by the temperature within the case.
Well, I hope what I have written make sense to those among you who have good experience when it comes to reducing noise within cases and I indeed look forward to your recommendations.
Thank you in advance
ps. my thread where I seek advise abut which fans to purchase
