http://www.directron.com/nibbletool.html
Just wanted to make sure I was gettting the correct thing before ordering. Thanks!
Square or rectangle, great but slow. Curved or circle, lots of filing afterwards, not worth it IMO.
If you want to make a hole for a fan get a 4 1/2" hole saw. Works great.
Actually, you'll want to cut it just a little smaller than the size of the CD, in order to account for the frame on the fan.Also, tracing the outside of CD/DVD is the exact size of a 120mm fan hole.
http://hardforum.com/showthread.php?t=1354736Is it real easy to get a straight edge, or are there going to be lots of jaggies? I've been looking through worklogs looking for pictures of the kind of hole it makes, but I can't seem to find any.
Essential case modding tools:
- nibbler
- rotary tool
- drill and drill bits
- hole saws
- files
- various screw drivers and bits
You can do A LOT with just those fairly inexpensive things.
i have that it is horrible
i would go for this one next time.
http://www.eastwoodco.com/shopping/...CT&iMainCat=1490&iSubCat=1490&iProductID=1434
