I'd advise getting used to the default controls, as the classic controls really gimp you. Some tips are to hold down L2 or Left Trigger when shooting at loose pucks, otherwise you'll hit and draw a penalty. Otherwise I find the controls work pretty well. What were your issues with them exactly, other than them being different?
Unless they added a speed burst since 09, there isn't one. The only way to speed burst in 09 was when you had the puck on a break you could dump it a few strides infront of you to gain a bit of speed. Haven't verified if this is in 10 still.
