new X11 kernel / 25-30% increase in perf with no power increase
DooLocsta
I switched over to this after reading about it in the Nvidia thread. After 6 hours with it I am a believer.
titan97
I didn't see much difference. I went from using the standard sgminer to this modified sphsgminer and I went from 2.35MH on my R9 290 (intensity at 17) to 2.45 (at intensity 17, 18, and 19).
collegeboy69us
my 270s (non X) are each pulling 1.7Mhash each now. Huge improvement.
Sadly I still feel the need to mine VertCoin since it's the most profitable. At the end of the day.
I'd love to find a good X11 multipool that auto cashes you out to BTC. Coinmine.pw and the blackcoin pool all do X11 but they don't cash you out.
Last thing I want to be sitting on is a small collection of 50-60 random shitcoins.
oblox
Has this been verified that it doesn't increase power consumption?
Also, for the BC Pool, why not just sell the BC then for BTC?
_r2h
I haven't been able to get this stable. Also having mixed results on poolside hash matching local hash.
Digital Viper-X-
I cannot comment on power directly.
However, my 290x is sitting low-mid 60s with fan hovering between 2800-3100rpm, which is where it was before this too.
noobferguson
And the arms race continues. Got a ~150khs bump for absolutely nothing. :D Heat and power seems to be the same
Oklahoma Wolf
PSU Warranty Voider
One word of caution for those running an HD7770 like me - the latest update to the new miner doesn't like this card. I had to use the original release with it, which gives me 900khs. Up from 600.
Also, I had to go down to one thread with my HD6870, otherwise I go from 1.4mhs to 800khs.
It's crazy - the 6870 is now as fast as the 270s all used to be.
mkrohn
crank threads up one at a time till it errors out I think 4 is where my 290's are at and 10 for my 290x
2 for threads brings a big increase to my 270/x
XViper
I'm getting about 3.876Mh/s on my 290x's. I just added my pool info and let it mine. Good stuff.
I'm using intensity of 18 unlike OP. I'm mining Cinnipool. I'm gonna just hold onto the coins. Hope it's worth something in the future.
JCviggen
My 7970s see a 50% gain :eek:
No noticeable increase in power consumption. A 4x7970 rig underclocked and undervolted now does 12.25 MH. VRM power as shown in HWinfo is around 50W GPU and 20W memory. Real power consumption is a bit more I suppose but still very impressive. 7970s seem slightly more efficient at X11 than my 290s
Nexillus
There is a slight power increase and depends on cards. On my 280x was about 15 watts per card, for my 7950's was about 10 watts per card and my 290s well whole different story :p Was about 35 more watts per card.
DooLocsta
Can you explain a little more on this? I have a 6870 as well but I can't get it to work with this so I am stuck at 900kh/s.
IEC
I'm getting 3.4MH/s per 290 at 940/1250 undervolted. I could get more with better clocks but would rather have the power efficiency.
collegeboy69us
my 290's are throwing hardware errors even on the most basic config... (x11)
wish they were as easy to tune as my bank of 270's lol
Anyone got a good TC setting for reference 290s?
DracoNB
Just use defaults, I haven't noticed any difference when trying multiple different settings.
Its obviously still not very optimized, I'm sure there are people using their own personal optimized miners getting massive hashrates at high (scrypt level) temps / power usage.
XViper
Did you do the setx commands already? I just installed this on another 290 rig and it works fine. The default TC is fine and it should work good just out of the box. All you have to do is put your pool info in.
Carbon_Rod
I have the same issue with only 1 of my 280X's... it's got the same config as every other card, but throws a hardware error once every few hours. I'm trying a few different things like lowering its voltage and intensity and seeing if it helps.
edge929
I think I'll finally move my 270 rig to x11. I had been looking at x11 (Hirocoin) back in March during the scrypt-coin dive but didn't pull the trigger. Heat isn't an issue where I live (at least not until August).
Kardonxt
It's nice to get the optimization but does it even matter now? I dont see any X11 coins that are reasonably profitable right now.
Carbon_Rod
I've actually been on Blackcoinpool for the past few days. Profitability is slightly higher than many other pools even if you instantly sell the BC you get paid.
mkrohn
I'm never a fan of speculation so I'd rather keep the reliable paycheck
Carbon_Rod
I'm with you there.
In my case I'm also building up a small stash of BC so I can have something to play with while the reliable paycheck comes in. The rest of my stash is currently in LTC (yarg!) which, as you know, has not been stellar as of late.
EDIT: Besides, I might as well get in my entries for their KNC Titan contest which means I have to have at least a certain amount of hash power pointed there.
Spidey329
Anyone here with a ref 290 getting good results with it? If you can, post your config. I'm getting HW errors or TC-fails to start. It won't accept my normal 290 values. A blank cfg with just pools produces non-stop HW errors. Tried a ton of different configs.
kache
3.5MH/s with 0.047 WU, seems good for me.
