New System
TrebsT
Gaming
5,500.00 DKK = 1,038.80 USD
3) Where do you live?
Denmark
4) What exact parts do you need for that budget? CPU, RAM, case, etc.
CPU, Ram, MB, CPU Cooler.
Corsair HX 850W PSU, GTX 295.
6) Will you be overclocking?
Yea
1080 HD
This Month i think
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
SLI
Windows 7 64 Bit
How much better will this system be than my old 1 ?
Or could 1 GTX 590 Or 6990 Do just as good as the new system ? :)
NEW
ASUS Sabertooth P67, Socket-1155
Corsair H70 Hydro Series CPU
Corsair Vengeance™ DDR3 1600MHz 8GB CL9
Intel Core™ i5 Quad Processor i5-2500K
Microsoft Windows 7 Home Premium DK
OLD
Q6600 At 3.6 Ghz
MB P5Q
GTX 295
4GB
A couple of not-so-good values in the new build:
1) The Sabertooth P67 is more expensive than the nearly identically-featured P8P67 Pro, and does not overclock any better or handle any higher of an overclock than the cheaper mobo.
2) The RAM that you selected is about 30% to 50% more expensive per GB than even other DDR3-1600 RAM of the same timings, let alone DDR3-1333 RAM. And with these LGA 1155 CPUs, the RAM has no effect on CPU overclockability.
3) I'd recommend a new graphics card as soon as possible. That GTX 295 is in reality two GTX 275 GPUs in one package, and it consumes much more power than most of the newer GPUs of equal or greater performance potential than the GTX 295.
Do you mean this MB ? http://www.komplett.dk/k/ki.aspx?sku=626381
About the RAM What kind would be better with the MB ? :)
And GFX I dont think i got money for a new 1 Atm. But when i got i am thinking about getting the MSI GeForce GTX 580.
Will be getting this i think :)
ASUS P8P67 PRO, Socket-1155
Corsair XMS3 DDR3 1333MHz 8GB CL9
MSI GeForce GTX 580 1536MB PhysX "Twin Frozr II"
Noctua NH-D14 CPU Cooler
Solid. Though the recent QC issues with the Asus P8P67 PRO motherboard has left me very hesitant in actually recommending it to others. I recommend this mobo instead:
$180 - MSI P67A-GD65 Intel P67 ATX Motherboard
(QC issues with the Asus P8P67 PRO motherboard)
Could you Explain what it means ? :)
Btw always used ASUS MBs so huge fan of those ^^
QC = Quality Control. It seems that a lot defective Asus P67 motherboards are hitting the market. It could be a QC issue or a just poor design issue. Either way, the latest patch of Asus P67 mobos have a slightly higher than average number of complaints judging from this subforum and the motherboard subforum.
