> Rather than PWM, seems like some sort of duty-cycle (15% off, 85% on, for example)
PWM means using duty-cycle to adjust average output.
> See how fat the pulses are, and 5, 15, and 20 are similar. 10 you can see the three pulses, but they are fat.
Do you have photos for assured PWM displays to be sure those are taken correctly? For example, you spoke of using different (and rather fast) shutter speeds which makes no sense. It also makes no sense the 5 setting is smoother than 10, AND the 7100 is claimed to be less "blurred" than the 6700 when it's continuous backlighting which makes the transition blurs visible.
Thanks. Very educational. So would you say that if the Samsung can use such a low PWM and have the "on" state of the pulse to be that long, the backlight must somehow be direct current controlled? For example, if at backlight 10, there is about 2 pulse of "on" time, with very minimal off time, there isn't much variation between two pulses and one continuous on at 20. I understand that the "width" of the pulse tends to be wider closer to 20. However, there is already a very wide pulse at level 10 versus 20. There's not much more room to change without it being continously on. Yet, there is still 10 levels of differences between 10-20. How does it control the brightness between 10-20 if the "on" state is already very wide at 10? Does it mean that somehow Samsung is controlling the intensity level behind the backlight some how along with PWM?
Normally, with PWM, level 10 should be something like this [] [] [] [], level 15 [ ][ ][ ][ ], and level 20, [------]. This is how the Samsung PWM should be at level 10. However, I'm seeing level 10 as [ ][-----][ ] which is not consistent with how PWM should be.
I thought the reason that higher rate PWM makes it easier on the eye because it more closely emulate a longer "on" time, therefore less on/off state, or flashing. If the "on" state of the backlight stays on longer but with a lower rate of pulsing, doesn't it emulate this same concept?
Rather than PWM, seems like some sort of duty-cycle (15% off, 85% on, for example), although that could be adjusted via PWM. That's the way it sounds from how he's explaining it, anyway.
You are right, it certainly figures.The problem isn't the on time, it's the off time. Lower freq means longer cycle.
They are short but not short enough for many display types.I thought the "refresh" (some blur) time is supposedly pretty short.
It's 1/25 shutter speed. This is why I mentioned that it's hybrid. The pictures don't lie, that's why I posted it.
Edit: Notice how lighter at backlight 5 than 15 and 20? Doesn't it make you believe it's some sort of direct current involved?
Here is the control. This is my old Dell (which looks like garbage next to this panel), it uses a fluorescent bulb, notice how thin the pulse lines are?
So we agree that my camera doesn't have a problem with capturing PWM lines?
GTA V looks awesome on my 48"! I just might keep it.
It took a few searches but here's Ziran's test/photo of the 7500 backlight @ 1/9s:
http://hardforum.com/showpost.php?p=1041516094&postcount=279
Looks like pretty standard PWM to me.
> You can adjust the pulse width while still having the same duty cycle, so long as the Period is also adjusted.
These backlights are pulsed at fixed freq afaik.
> To detect what is really happening, the pulses need to be viewed in the time domain because the whole screen is lit at the same time.
The way the test is done is by moving the camera across a line or whatever, the resulting motion blur through its shutter opening period is time-domain.
> This will be under a backlight control setting. Mine on my LG TV is called Power Saving and gives me 3 different max light levels.
Ziran tested the Eco level on his 7500 and it's same thing as lowering backlight setting.
edit:
Again to clarify. You're moving the camera against static lines and not using something like this which is not a PWM test, right?: http://www.testufo.com/#test=blurtr...&thickness=1&height=-1&ppf=16&separation=1000
I just realized what a bunch of nerds we are. Analyzing this stuff to the Nth level.
How about this: buy it with a safe return policy. Does it make you squeal with joy? If so, keep it. Why are we over-analyzing everything?
I just came to this revelation after playing a few hours of GTA V on my 48JU6700. It's freaking awesome. No regrets. I could be happy with this display for the next few years, yet we spend hours/days and debate in endless posts about what's marginally better. Trying to find that extra 1%...
Carry on.
Are we sure that PWM is ONLY affected by the 'Backlight' setting?
I'm not convinced that the Contrast & Brightness settings don't also affect PWM. This may explain some of the inconsistencies - if Contrast, for instance, wasn't at the same level while adjusting and measuring different backlight settings. It seems whether you adjust Contrast, HDMI Black Level, or Backlight Level or even brightness, it's all basically doing almost the same thing and ends up at the same result, IMO.
These backlights are pulsed at fixed freq afaik. PWM is just a fancy way of saying changing the duty cycle to adjust average output.
Ziran tested the Eco level on his 7500 and it's same thing as lowering backlight setting. Is the LG one actually lower levels?
edit: Actually I'm not sure what the model in Ziran's photos is. He mentioned the 7500 just before the posts, but 120hz pwm seems pretty ridiculous for a 240hz set. Maybe it lowers freq for <240hz refreshes or I misread the model he's talking about.
48JU7500
And yes its 120Hz PWM.
Here is an even better picture at 20 back light brightness (and moving camera MUCH faster):
http://i.imgur.com/3K7iDdH.jpg
You can see there there is a little PWM even at 20 back light. And it is 120Hz (1/9s shutter and 13 bands)
Also 48JU7500 has a "Motion Rate 240" that is not the same thing as 240Hz refresh. In fact I am pretty sure it is 120Hz actual internal maximum refresh (with the 6500/6700 having maximum 60Hz refresh and "Motion Rate 120"). But the only way to use the 120Hz refresh is in the "movie" mode to enable fake frames to be inserted in (high lag looks bad for computer images), or to insert a blank frame every frame. That 60Hz black frame causes horrible flicker so its unusable (it works much better at 24Hz for movies).
It is possible that the 7000 lines does have a panel with a better response to enable it to use the 120Hz internal refresh rate. But other then less blur there is no way to use it directly in PC or GAME mode.
All I'm really hoping for is less blur. Less enough to make the switch worth the $. We'll see.
Problem is, there's NO way I can go baack now though - I've tasted the curved 4K fruit and it is SWEET.
So Monoprice is really dropping the ball on their 18GBPs Redmere Ultra Thin HDMI cables. I ordered a 6' from Amazon and it is dropping out constantly (about every 3-4 minutes when playing games). I swapped it out with an old FAT Monoprice 'high-speed' HDMI cable I had and have had no more issues. I'm going to call MP on Monday and tell them all of the woes we're having with their cables.
This is the cable that doesn't work:
http://www.amazon.com/gp/product/B00KFSP070/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
That's a misunderstanding of what's actually going on.
No it is not, it's an anecdote about what I observe when comparing a monitor without PWM to one with PWM, which is something I have done numerous times. It's irrational to think that blurred content does not look worse on a display with PWM compared to one without, but it does not surprise me that you think it does not, nor does your dismissal of the similarities between Blur Busters and Rtings results, and neither does your attempt to imply Rtings reviewers are incompetent. It's possible that Rtings did use different shutter speeds, but it won't make much of a difference unless the shutter speeds are quite different.
IIf the tripe above is what the display review sites are pushing, then they simply don't understand display/image basics and therefore whatever they might get right is a matter of coincidence.
That Crossover panel is garbage, one that makes that hilarious $299 43" Quasar look a Kuro...
Carry on.
Brahmzy will break it all down in a few days, looking forward to it.
But you can tell how happy the guys who took delivery a week ago are with their 6500/6700s though because they've gone quiet in the thread the past few days...
No time to post when you're playing with your new toy for hours on end lol.
Please let me know when you have published your article about superior testing methodology and disproven what we know about PWM. Mark Rejhon and TFT Central will be very interested in your article, as will all of the major display manufacturers since they will be able to use your article to justify the use of low frequency PWM and save a ton of money.
But if it works for you and your strange ultra-ultra-sensitivity to any PWM, even at the cost of image quality, by all means go for it...and I say that without snark.
We all have to do whatever works for us, our own individual choice. It's all just opinion, and I choose my opinion over yours NCX. Just as your opinion, to you, is a better fit than mine is for you.
Amazing how that works.
Apparently these expert blur hunters never figured out how cameras or displays work.
@Cyph, haven't heard of any dead pixels from anyone - very impressive.
Keep in mind also, that these are TVs, not computer monitors. I think Samsung expects the majority to be sitting 5-10ft away (not 18-24") from these which greatly lessens the affects of PWM for those that are sensitive to it.
Also, this infatuation with PWM is perculiar. Samsung expects to sell hundreds of thousands if not millions of these panels to people all over the world and some people can be expected to watch TV for 8-12 hours at a time. If a company with billions of dollars in resources that sell TVs at 3-5ks at a time (the bigger sizes get quite expensive), thinks people are going to get fatigued and return them, they're going to lose money. They obviously don't believe it to be a problem.
LOL. Good morning.
Boy I wish those MI shots were what we could use! How much latency do they add? Something like 100ms??
I think one reason we're 'nerding out' here is the fact that quite a few of us ARE sensitive (to varying degrees) to PWM and/or BLUR. Yet we're desperately wanting large 4K monitors. I came off two years of using one of the fastest, largest 16:10 non-TN panels you can buy, with no visible PWM (hella IPS glow though.) Part of this new display is a huge step back for me in areas that are pretty important.
So, that said, I think we're trying to understand if there are any possible ways to optimize our viewing and to full understand the limitations of the things we can't. I don't want to send it back - I want it to work the way I need it to, which is why I'm willing to check the 7500 out.
