I am still sore from the last set.
7623
7624
7625
7626
I have a 7625 currently that I was getting ~13k ppd on with my GTX660ti
I am now getting ~37k after refreshing projects with HFM.
Spin the wheel to see what PPD you will get!
These WUs took my 560ti (448 core) 7+ minutes to complete 1 frame.....rediculously slow comparing to 8054/8057 -- around 2min/frame
But I do agree these are evil because of the temp rise.
If you don't have temp issues running these, you need to overclock more.../looks at his MSI Twin Frozer GTX 660ti
/shruggs
I have a stock evga 560 ti fps version and @70% fan its getting to 93C, up from 85C at 63% fan.
I'm knocking out 27/28 k with a tpf of 7:22min
For the 762x you need to cut back on the OC to drop the temps.
Wow, I wish I was as brave as some of you guys.I have a stock evga 560 ti fps version and @70% fan its getting to 93C, up from 85C at 63% fan.
I would manually set the fan to 100%, 93C is getting very warm, i usually like to run mid 80's at max when i gpu fold
I normally try to keep mine under 60c but have let it climb up to 75c on these evil units.
Right now I'm at 67c on a 7624 with OC at 911/1822 on my 460.
I know it can run hotter, I just prefer not to.For CPUs .. yes, you wanna keep temp around 60, but for GPU, it can handle much higher than that.
Back in "good old day" when GPUs "ruled" the world.. all my GPUs ran around 90C for months (if not YEARS) with no issue
My GTX660ti is doing 5:26 per frame. I'm looking forward to an optimized core that will drop that TPF. Should be on it's way.... some time.
Edit: I now have a 7624 and am getting 4:27 TPF with 45600 PPD. I'll take it.
8:08 on 7624 with my 460I've got the same card as Kendrak (I copied him) but a slightly slower version and its getting a 5:38 per frame. My 460, on the other hand, is at 8:55.
I have two 7624s running right now on GTX 650Tis but am seeing different numbers. They were both issued within an hour or so of each other.
On a 8-core rig, I'm seeing a base credit of 14093 @ 18449ppd.
On a 4-core rig, I'm seeing a base credit of 5187 @ 7767ppd.
The TPFs are 9:23 on the 4-core rig. I took a bad power hit last night and forgot to OC the GPU on the 8-core rig, but the base and pdd credits are higher on that rig.
Anything I should check on the v7 console? Or could the discrepancy be based on the power hit I took and how the boxes reacted to it? Or is it just variation between different 7624 wus?
Thanks!
Thanks!
Check your temperatures, but also ensure 3d clocks have engaged.
gpu-z or precision can show that.
Oddly though your base scre isn't right, are you monitoring both on 1 pc
Thanks! I'll try to figure this out as the 762* units come in on the questionable box. I checked my log and it might have been due to taking a power hit and having the card flagged as unstable before a core restart.
Can't afford UPSs except for keeping the batteries in the laptops.
Odd thing is that after the core restart, temps and the TPFs looked good, it was just the base/expected/and PPD numbers looked way low. Just just in case, I backed off the OC from 1100 to 1050 until I can take it off-line to tune the fans.
The questionable quad box is chomping through an 8073 Base 3874/Estimated 3874/17709 PPD with a 3:09 TPF. I guess I just need to be patient.
My other two GTX 650Ti's are showing 21K ppd with 7625s and 7623s.
