New Pc Build
atlrocks07
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing?
Programming,Virtualbox,Webdesign, Web browser
Not higher than 1500
Lafayette La
Cpu, Video Card, Mobo, SSD, DVD writer, cooler, ram, hard drive
Case, old evga 7600 video card, sata dvd burner
6) Will you be overclocking?
Yes
2-22+
With the next month
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Sata 6gb, usb 3.0
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Windows 7 Pro 64bit
Monitors - Acer S231HLbid Black 23 http://www.newegg.com/Product/Product.aspx?Item=N82E16824009255
Video Card - EVGA 01G-P3-1450-TR GeForce GTS 450 http://www.newegg.com/Product/Product.aspx?Item=N82E16814130572
Power Supply - CORSAIR Enthusiast Series TX650 V2 650 http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
Motherboard - ASUS P8P67 DELUXE http://www.newegg.com/Product/Product.aspx?Item=N82E16813131701
Processor - Intel Core i7-2600K Sandy Bridge 3.4GHz http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
Memory - G.SKILL 16GB (4 x 4GB) DDR3 1600 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231315
OS Harddrive - Crucial M4 CT064M4SSD2 2.5" 64GB http://www.newegg.com/Product/Product.aspx?Item=N82E16820148441
Storage Harddrive - Western Digital Caviar Black WD1002FAEX 1TB http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
Any reason you choose the Deluxe board over the PRO? A lot of people recommend the MSI boards over Asus because of some early issues Asus had (I never had any though). Something to think about though. Also, do you need a black drive for the second drive? Assuming it is just for storage, you can save some power, heat, and money by going with a Caviar Green drive instead.
Any particular reason why you want to spend this much on a video card? You should be fine with a cheapp HD 5450 or HD 6450 unless the applications you're using takes advantage of Nvidia's CUDA tech.
Nothing you've said justifies that motherboard considering that this cheaper mobo meets all the requirements you've stated so far:
$170 - MSI P67A-GD65 Intel P67 ATX Motherboard
This Samsung actually performs the same as that WD Black drive while being $30 less:
$60 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
Also, what case are you reusing?
