I took some more photos, i noticed that variables in camera that effect how the display looks are: Shutter speed (emphasizes colors); Light source (light bulb - makes screen blue, daylight - colours more as i see them); Distance - further away --> less backlight bleed.
Here you can see varieties, but you should see those at 1/8s on black background.
http://ogledalo.si/nec/variations/
1. Shutter speed: 1/8 s Distance:50cm Light source: Daylight
2. Shutter speed: 1/8 s Distance:50cm Light source: Lightbulb
3. Shutter speed: 1/8 s Distance:90cm Light source: Daylight
4. Shutter speed: 1/1s Distance:50cm Light source: Daylight
5. Shutter speed: 1/1s Distance:50cm Light source: Lightbulb
At 90cm it looks OK, but i am usually 45-65cm away.
I guess i am quite sensitive, but i dont like it when i compare NEC20WGX2 that costs more than twice as much as Samsung 740T and Samsung has better uniformity and no goldish brownish corner. If i observe very precisely Samsung only has blueish corners, but much less visible than NEC. Colours, on the other hand, are quite better than 740T.
And yes, display gets all gold at diagonal view. From vertical angle, it gets gold on left and right side, from horizontal angle it gets blueish/violet on top and bottom. In both cases - vertical or horizontal angle it is black in the middle. : )
