Hey guys, just wanted to get some opinions before I started ordering any parts.
Gaming/light photoshop/ web browsing/ e-mail/ MSoffice
around $1000-1200
3) Where do you live?
Florida
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything but case/dvd-drive
Case/Dvd-drive
6) Will you be overclocking?
Yes, moderate/safe oc'ing
20.1" 1680x1050
Next week or so
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
RAID support preferably, SLI doesn't really matter to me right now
10) Do you already have a legit and reusable/transferable OS key/license?
Planning to buy Windows vista 64bit OEM~$99
This is what i've been looking at:
MSI X58 Pro LGA 1366 Intel X58 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130221 200
XFX GX260NADFF GeForce GTX 260 Core 216 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16814150329 210
RAIDMAX QUANTUM RX-700 700W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready Active PFC SLI Power Supply - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16817152033 100
Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920 - Retail http://www.newegg.com/Product /Product.aspx?Item=N82E16819115202 290
OCZ Solid Series OCZSSD2-1SLD60G 2.5" 60GB SATA II - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16820227373 160
OCZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model OCZ3P1600LV6GK - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16820227381 110
ASUS Xonar D1 7.1 Channels PCI Interface Sound Card - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16829132007 90
Microsoft Windows Vista Home Premium SP1 64-bit for System Builders - OEM http://www.newegg.com/Product/Product.aspx?Item=N82E16832116488 99
PLANTRONICS .Audio 650 USB Circumaural Multimedia Stereo Headset http://www.newegg.com/Product/Product.aspx?Item=N82E16826265044 35
Total ~ 1294 a lil over my budget
I was considering an alternate build with a q6600, 4gb ddr2-1066, and a cheaper motherboard.
Also considering 2x160gb WD HD's in RAID 0 over the SSD
Any thoughts on better/cheaper components?
Appreciate any input,
Thanks
around $1000-1200
Florida
Case/Dvd-drive
20.1" 1680x1050
Next week or so
Thanks
