New gaming PC build help
xpronic
Gaming.
£1.3k with shipping.
3) Where do you live?
UK
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Monitor, Case, PSU, MOBO, CPU, RAM, GPU, Sound Card, HDD, Optical Drive
None.
6) Will you be overclocking?
Most likely.
Plan to use 22" monitor.
ASAP.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Space for adding more HDD in future and second GPU if needed.
10) Do you already have a legit and reusable/transferable OS key/license?
No, I plan to buy a new copy of Windows 7.
Please answer the stickied "ANSWER THESE QUESTIONS FIRST" so that we can help you better.
on a 30 inch monitor you might be comfortable with half resolution (quarter technically)
I've updated my original post with the required info for help building a new PC. :)
I plan to keep that on my current PC as it's more useful for work related tasks.
Since UK sites are too slow to load for me, I can't check prices. So, here's a couple configs to consider...
AMD PhenomII X4 945 or 955 BE, or X3 720
AMD 770 AM3 only mobo, eg. GA-MA770T-UD3P
OR
Intel Core i5 750
P55 mobo, eg. GA-P55A-UD3
RAM: 4GB DDR3-1600 or DDR3-1333 CL9 or lower, 1.65v or lower
GPU: HD 5770 vidcard, XFX or VisionTek
HDD: Samsung F3 500GB/1TB, WD Caviar Blue/Black 640GB/1TB
Optical: Any SATA DVD Burner
PSU: Corsair VX550/650, Antec TP-550/650, or Antec EA500/EA650
Case: Cases are subjective, but I'd recommend any of the following: CM RC-690, CM Centurion 532, 534 or 590, Antec P183, CM Scout, HAF922, HAF932, etc
