New Build - Live streaming, Gaming, Work
Offbeat
Just so you can see what I'm upgrading from; this is what I've been using for the past 4 years.
Q6600 @ 2.4ghz (lol Dell)
4 GB corsair dominator
HD 6850
This will be my first PC build :D
Photoshop CS5.1, Dreamweaver, Live streaming webcam/game simultaneously (WoW, Diablo3, Dota2, though we have no idea how resource intensive these games will be)
I will regularly have ~10 chrome window, and skype open while working(ps+dw) or when gaming.
700-850$ shipping included(though I can budge a bit if necessary), no sales tax here.
3) Where do you live?
Delaware
Case, CPU, RAM, Mobo, PSU, SSD, DVDR, (maybe GPU? you tell me)
I have a HD 6850 from my current PC, just bought this in march when my HD 4890 was overheating and I didn't want to wait for it to go back and forth through the mail before I could use my computer again lol.
I will also use my 2 extra HDDs that are in my current computer, for FRAPS/movies/music/graphic work.
6) Will you be overclocking?
I would like to, since I heard it's incredibly easy with the new CPUs' that are out :)
I have a 24" @ 1920x1200, I will buy another 23 or 24 eventually. (i will only play games on 1 monitor)
1 or 2 weeks at the latest
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
I think SATA 6Gb/s would be nice to have.
Yes, Windows 7 ultimate 64bit
I'll be back in 30min with a build, if someone else hasn't. I'm sorry, I saw this last night on my tablet and didn't pull the energy to help :(
mobo 130usd
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157253 ASRock P67 mobo - has SATA III/6gbps
case 40usd
http://www.newegg.com/Product/Product.aspx?Item=N82E16811233039 Just a normal case. May be cheaper to pick up a decent one locally.
RAM 60usd
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231422 GSkill 8GB 1333 RAM
CPU/SSD combo 317usd
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.673401 i5 2500k + M4 64GB
2TB HDD 120usd
http://www.newegg.com/Product/Product.aspx?Item=N82E16822145473 Hitachi 7200RPM
BluRay burner OEM 85usd
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135252 ASUS OEM BLuRay burner
PSU 90usd
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371026 Antec Earthwatts 750 (doesn't come with power cable, btw).
should be about 880usd with shipping. Not the best build in terms of performance/$$ :( I'm sorry.
The CPU/SSD combo expires pretty soon, afaik.
$325 - Intel Core i5 2500K CPU + MSI P67A-G45 Intel P67 ATX Motherboard Combo
$60 - G.Skill Value Series F3-10600CL9D-8GBNT 2 x 4GB DDR3 1333 RAM
$117 - Crucial M4 CT064M4SSD2 2.5" 64GB SSD
$19 - LG iHAS124-04 DVD Burner
$110 - Corsair 750TX V2 750W PSU
Total: $631 plus tax and shipping
As for replacing your GPU, is your HD 6850 currently meeting your needs in the games you're playing right now? Or do you want higher settings, higher FPS, or both?
Case wise, choose your own case. I highly recommend any of these cases:
$70 - Lian Li Lancool PC-K58W ATX Case
$90 - Lian Li Lancool PC-K56 ATX Case
$90 - Cooler Master CM690 II Advance ATX Case
$90 - Lian Li Lancool PC-K7B ATX Case
$100 - Lian Li PC-7B Plus II ATX Case
$100 - Cooler Master HAF 922 RC-922M-KKN1-GP ATX Case
$110 - NZXT Whisper WHI - 001BK ATX Full Tower Case
$110 - Lian Li PC-60FN ATX Case
$110 - Lian Li PC-7FN ATX Case
$120 - Velocity Micro GX2-W Silver Classic Aluminum Case with Side Window
$127 - Fractal Design Define R3 Black ATX Case
$140 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$140 - NZXT Phantom PHAN-001BK Black Full Tower ATX Case
$140 - Lian Li PC-9F ATX Case
$143 - NZXT Phantom PHAN-002OR Black Finish w/Orange Trim Full Tower ATX Case
The only game I play right now is WoW, and it handles it fine. I would like to be able to play with higher FPS when in more crowded areas. A lot of people tell me that a better cpu will help more with that. I suppose I will hold off on a GPU, unless i'm not satisfied.
You don't think the i7 is worth the extra 100$?
thanks for the help
The i7 is worth the extra 100usd if livestreaming is really resource intensive, however, it's not going to do much for normal gaming.
For your needs, the i7-2600K isn't worth the money.
For another case option, the Cooler Master HAF 912 is still a pretty good choice. Most, if not all of the cases in Danny's list has free ground shipping, but that HAF 912 at around $68 shipped isn't bad.
The 6850 is most definitely going to meet your needs. An i7 is not worth the money as there is no difference when it comes to gaming, so a 2500k is the best choice. If you really, really feel the need to upgrade your gpu go for another 6850 as the ATI 6xxx series have seriously good scaling. Otherwise, wait for the new 7xxx series to come out and pick up another one when they're cheaper.
The Core i7 processors are generally recommend for heavy multi-threaded operations such as video editing, 3D graphics editing, or running multiple virtual machines (VMs) at the same time. Though Photoshop and Dreamweaver gain a slight performance bump with the i7-2600K over the i5-2500K, I don't believe that the performance boost is significant enough to justify the added cost.
I'm curious as to why the Lancool PC-K57 is being skipped over on your case lists, Danny Bui. I ordered the windowless version (out of stock right now) a couple nights ago. Looks solid and the two reviews I found are good. (not criticizing at all; just wondering if you had a significant reason for excluding it)
Not a bad case at all from a performnace, case management, airflow, or space standpoint. It just looks really really ugly to me. Well the front portion anyway. Hence why it isn't in my case list now. :D Key word "now". That case may grow on me one of these days.
Funny, it's looks are actually what made me stop and take a closer look. :) It's good to hear there's nothing wrong with it practically speaking.
Just now getting around to buying everything. Going to order everything when I get back home later tonight.
I missed out on a little discount, but it's no real big deal I guess.
Is there anything you would change from the original list before I order it, Danny Bui?
thanks a lot for all of the help :)
I would ditch that 750TX V2 as it's jumped up significantly in price. I recommend this PSU:
$90 - Corsair 650TX V2 650W PSU
Go with Danny's recommendations in post #7 save for the PSU (look at his most recent post).
I also suggest choosing one of the cases that Danny recommended in that post.
Got my parts on Wednesday, and put everything together yesterday. Surprisingly to myself, there were no real hiccups at all for my first build.
Only thing that was annoying was getting all of the cables where I wanted them. I got the Cooler Master CM690 II Advance
Going from q6600 at stock speed to a 2500k is ridiculous. I would get ~12 fps when streaming WoW before; now I can't even notice that I have the stream running. I don't usually spend more than a second or two on loading screens now with the SSD. I love it. :D
thanks a lot for the help
