new box processor your thoughts
hey all
am finally getting round to making a new system
will basically be a gaming/media center with an OCing later on if needs be,
looking at either
a
AMD Athlon 64 X2 5200+, dual core, socket AM2, 2.6GHz
or
AMD Athlon 64 X2 5000+, dual core, socket AM2, 2.6GHz
im just getting into the start of it and need to do more research but im hoping you guys can give me a nudge in the right direction and i can start sketching out a system.
thoughts etc greatly appreciated!
RogueTrip
if your up in that price range, you'd be better off with core2 duo setup, it even has better oc'ability.
Fangs404
I know you're posting in the AMD section, but have you given any thought to a C2D system? It's really your best bang for your buck, especially if you're planning on OCing like you say you might. The 5000+ is $215 on Newegg, the 5200+ is $225, and you can get the E6400 for $221. The E6400 will outperform both, especially when overclocked.
That said, if you're dead-set on an AM2 system, get the 5200+. For only $10, double the L2 cache is definitely worth it.
Boltaction
like the others have stated, since you are buying all new parts you should highly consider Intel. Check any review site.
Also: can you link the 3600+ brisbane and mobo combo deal?
kirbyrj
