SonDa5
- Aug 20, 2008
Soji I like the simplicity of your loop. Looks great. How does it cool? Is that Radiator enough?
Can you guys offer some assistance? How do you justify the cost of watercooling? I figure upgrades for water blocks is cheaper after the intial setup, but water blocks seem to be just as expensive or half the cost of the card. That and I can't seem to find water blocks now that Danger Den is gone for my old 6970. I gotta convince my finacial advisor with just reasons and 500$ is rough to say better temps, better fps, and quieter room.
I think it is... I have done dual single thickness swiftech rads cooling an amd hex at 4ghz a 5970 and 5870. I bet his D5 pushes enough to keep it cool...I love those pumps.Soji I like the simplicity of your loop. Looks great. How does it cool? Is that Radiator enough?
It's been a long time since I posted but couple months ago, I started trolling an after doing some research, I just finished my new rig:
System Specs:
Fractal Define R4 Case
Asus Sabertooth Z77
Intel 3770k CPU
Corsair 16gb 1866
Samsung 830 SSD
Nvidia 680 GTX 4gb
Corsair TX650 PSU
NXZT Fan Controller
Water Cooling Specs:
EK Geforce 680 GTX Block
Koolance CPU-380I Block
Coolgate 240 Radiator
Aquacool VP655
Bitspower 150 Upgrade kit
Bitspower Pump Top
Bitspower Red Pump Mod Kit
Dangerden Dreamflex 1/2ID - 3/4OD
Phobya Compression Fittings
Yate Loon 140mm High
I guess I did it that way, I because I want the coolest water to goto the CPU first
Posted from Hardforum.com App for Android
Nice! Is there any benefit to using the fittings to make angles etc around the cpu and gpu blocks (as opposed to just the tubing)? Or is it just for aesthetics? Looks amazing!
Excuse the awful picture but here's my new rig:
Just a quick little teaser while im finishing it up and adding lighting etc
Caselabs STH10
Asus Maximus V Extreme
i7 3770K
Crucial Ballistix Tactical Tracer Ram
Onboard Crucial M4 SSD
3 x 7970 Tri-fire
AX1200
Cooling:
MCP35x Pump
FrozenQ Helix Res
2x 480mm Monsta 80mm thick rads
Apogee HD CPU Block
3x Komodo 7970 GPU Blocks
Bitspower Compression Fittings
Swiftech Helix Fans controlled by Bitfenix Recon
Caselabs STH10
i7 3770K
3 x 7970 Tri-fire
AX1200
Cooling:
MCP35x Pump
FrozenQ Helix Res
Apogee HD CPU Block
I attempted...it didn't fit. I've got a 240 rad sitting around and that one barely fits. No way the 280 fits.I'm wondering why you didn't put the radiator in the case? I have that same case and mine fit, just wondering that's all.
3 480's are CRAZY, lol. I like it.
Agreed -- fantastic bending skills. No stress on the components?
Looks great.
Very nice. I have one of those cases in storage. I forgot about how much room they have, and how heavy they are. I should go un-retire it from storage.
Like the copper.
Looks great.
+1 on the copper tubing. No, +2.
Couple questions:
What block is it that connects to the top of the reservoir?
Which pump are you using? Is that apump mount below the pump?
My last shots before I move everything out of this case. Bye-bye 500R ...
* Pictures removed *
I'll be "Switch"ing over to an 810 with a different color scheme and a similar, but more improved loop.
Really eager to seeing your next loop. I was really impressed by this 500R loop you had. I prefered it without the lightning, but it's still a really nice job.![]()
^as I will be. I really want to do an 810 with a lambo yellow paint job. not sure why, but seeing an awesome loop in one may make me want it more.![]()
