- Aug 3, 2004
APC and Tripp-lite are all i know!
equipment list?Skeltek Rack arrived..worked on it the last couple of days. A lot of this setup is temporary and I still have to run cabling from the rooms in the house and replace my dlink with a managed switch for Vlans, LACP..etc. Pics aren't the greatest..used my cell phone. Love the Skeltek. I also got the rails since the supermicro case rails are too long.
equipment list?
interesting that you shortened the door. previous employer had a smilar setup, room retrofitted with raised flooring, and the left the door, but installed a ramp, was much easier to get gear in and out.
Ramp would have been nice, but cheaper this way. We now refer to it in an "un-politically correct" fashion as the Midget-Door
would be harder for some one to steal that rack and escape the room LOL!! good work looks awesome.
No trying to rain on your parade, its definitely cool.
Whats the point of raised flooring if you dont have a CRAC unit?
Carpet + Feet = Static
Also, I get to run all the cables under the flooring. It also makes the cooling space smaller.
I'm also going to add a 2nd cabinet and those plastic dangling things that they use in meat freezer things to do a hot/cold side with a return vent.
EDIT: It also just looks fucking good.
Nice setup Mike, only thing I would of maybe done differently is turned the racks around to make it easier to load equipment when you add a second rack. its going to start getting a little tight when you put the other rack in there. but I see the wall AC unit so I understand why you did what you did.
I would paint the inside of that window with black paint, that will make it look like a room with no lights on from the outside. Then fill the inside with a stud wall and drywall over it. That way if someone ever breaks it they cant get in. Buddy of mine did something similar when he built a home theater room. Cant even tell what is there.
I am sure the fire inspector will love the cut door lol. No way that is up to code. you should have just reversed the hinges. However in the long run the raised floor is worth it just make sure you keep the underside tidy, it can get out of control fast.
Now go get a CRAC and an underfloor fire system!
Since painting a window is generally a bad idea, why not tint the window. If the window was ever broken, the tint would help hold it together. It is relatively cheap and would also block out the view of the equipment.
New toys:
Some serious IOPS there, what is it going to be used for?
Something tells me the SSD's will be for FAST cache
We are now evaluating Compellent and EMC. Compellent software wise seems great, EMC however has a great history (minus the AX4).
Obviously, this is just my opinion based on my experiences and no I don't work for EMC, yet. We also have a Clariion CX4-240 and we absolutely love that and it works extremely well.
I went down the same path as well. Compellent is a very nice system. I like they way they do their tiering. Why I went with EMC is quite simple really, the system will primarily be used for VMware products. They lead the way when it comes to integration/tools..etc to vSphere, not too mention the obvious ownership of VMware. Too me..that says a lot and provides a nice comfort level. Another reason is as you stated the history with our CX4-240. The support is decent and the community is robust and very pro-VMware. If I ever have a problem, the resource pool is huge..and i'm confident the problem will be addressed.
what do you think of DataDomain so far ?
EMC seems to suck when I I try to add recently purchased disks to a storage pool.
I personally don't use it...we looked into it really didn't fit our needs. We are a shared shop, meaning many clients leveraging and sharing systems, allocating costs..etc, problem is DR sites are different..etc. It just wasn't cost effective and our gov't client still requires us to use tape believe it or not..and yes..i've explained the benefits. They are just one of our clients that will not accept change.
What's funny is ACS/Xerox is the biggest EMC Data Domain Customer..lol. I'm in the wrong division..
We are so far behind...trying to play catch up...just very difficult. Over the last 5-6 years we have had such a noose on cash investment in IT we pretty much couldn't do anything. Even if I showed a savings by going to vSphere and UCS, they still balked at the upfront cost even though it saved them almost $100k in the next year.
To me, this is a complete disconnect with IT and the Business side...and it's not getting any better. From my standpoint..it's time to move on.
