- Nov 16, 2005
I like this idea!
I've stopped buying electronic toys, i'm selling off most of my network gear actually. Getting more into hobbies that have nothing to do with my career, for the sake of my sanity. I've instead decided to build a massive garage, and started buying motorcycles and woodworking tools
not so much network porn, but I've moved more than 2 racks worth of stuff out of my basement and into garagezilla:
Don't get me started, I just got the OK for a 32x60 pole building to put my hobby machine shop, car lift, welders, cnc plasma, and toy cars. The next two months are going to be hectic.
All this talk of power consumption. I'm doing a lot of work trying to hook everything up to monitors and logging/graphing etc... You can see my server rack is sitting about 130 Watts idle- which isn't bad for the UPS, ESXi server, 24 port gigabit managed switch and 1x WHS 2011 fileserver. Unfortunately I have another 24 port gigabit managed switch running in the house and some a/v gear which idles at probably another 100 Watts...
I'm using gear from Current Cost http://currentcost.com/ (sold on eBay and Amazon). I've talked about it in a number of blogs (currently wrestling trying to get gas and water logged too): http://tickett.wordpress.com/
ROISomeone give me a reason I shouldn't have 40Gbps at home...
http://www.epartsandmore.com/produc...cts_id=2669&osCsid=cfp2gg5utm5klm4vl0pe9lugf2
I have not made much changes to my setup since my last post, but thought I'd post it again.
And this is a render of the setup, to scale, more or less:
I have been planning out what I want to do for the actual server room so I will be putting it on paper soon. I'm pretty much going stud per stud, and the reason for that is some of my clearances are very tight so I need to ensure everything will be ok once it's done. The electrical panel will probably go on that wall where the raid can is, that's the only place where the clearance will be legal. I may be able to put it where the stairs are but the wall's thickness may not work out. So I'll play with that in AutoCAD.
I'm even debating on not bothering with an electrical panel, and just run several circuits from the main one, though it's full so I kinda want to just run a sub panel, easier.
Also my first time actually applying a real life texture in CAD, so that was fun. Turned out ok, though the brightness is still offset throughout the image, but I did it quickly anyway. Idealy what I should have done is just use a single block then draw the mortar myself so the brightness is consistent.
I also put the lighting anywhere in the CAD, so it's not matching what is currently there. When I do the server room I'll probably have a fluorescent fixture in front and back of the rack.
What software is this? I assume it's some sort of monitoring software?
You guys have so much space!
lol yeah, I own my own house all to myself, not married or anything. It's awesome!![]()
Current network status:
Left rack: servers and storage
Middle rack: power/network and lab server (esxi)
Right rack + everything next to it: lab stuff
On top of right rack: new servers.
Current situation is a bit messy because i'm going to replace my old servers (left rack and lab server in the middle) with some new machines (the ones on top of the lab rack).
