LaCuNa
Hello people of [H] :D <3
I have a rapture GT-AC5300 router, connected through a Huawaei b168s.
I recently updated the Asus router to the newest firmware. Besides updating, I haven't changed any settings and all of the sudden this started appearing in the logs:
Dec 15 04:23:35 kernel: net_ratelimit: 643 callbacks suppressed
Dec 15 04:23:40 kernel: net_ratelimit: 650 callbacks suppressed
Dec 15 04:23:45 kernel: net_ratelimit: 652 callbacks suppressed
Dec 15 04:23:50 kernel: net_ratelimit: 626 callbacks suppressed
Dec 15 04:23:55 kernel: net_ratelimit: 644 callbacks suppressed
Dec 15 04:24:00 kernel: net_ratelimit: 675 callbacks suppressed
Dec 15 04:24:05 kernel: net_ratelimit: 634 callbacks suppressed
Dec 15 04:24:10 kernel: net_ratelimit: 672 callbacks suppressed
Dec 15 04:24:15 kernel: net_ratelimit: 689 callbacks suppressed
Dec 15 04:24:20 kernel: net_ratelimit: 655 callbacks suppressed
Dec 15 04:24:25 kernel: net_ratelimit: 665 callbacks suppressed
Dec 15 04:24:30 kernel: net_ratelimit: 626 callbacks suppressed
Dec 15 04:24:35 kernel: net_ratelimit: 633 callbacks suppressed
Dec 15 04:24:40 kernel: net_ratelimit: 659 callbacks suppressed
Dec 15 04:24:45 kernel: net_ratelimit: 651 callbacks suppressed
Dec 15 04:24:50 kernel: net_ratelimit: 637 callbacks suppressed
Dec 15 04:24:55 kernel: net_ratelimit: 844 callbacks suppressed
Dec 15 04:25:00 kernel: net_ratelimit: 1252 callbacks suppressed
Dec 15 04:25:05 kernel: net_ratelimit: 3207 callbacks suppressed
Dec 15 04:25:10 kernel: net_ratelimit: 856 callbacks suppressed
Dec 15 04:25:15 kernel: net_ratelimit: 703 callbacks suppressed
Dec 15 04:25:20 kernel: net_ratelimit: 644 callbacks suppressed
Dec 15 04:25:25 kernel: net_ratelimit: 661 callbacks suppressed
Dec 15 04:25:30 kernel: net_ratelimit: 756 callbacks suppressed
Dec 15 04:25:35 kernel: net_ratelimit: 648 callbacks suppressed
Dec 15 04:25:40 kernel: net_ratelimit: 756 callbacks suppressed
Dec 15 04:25:45 kernel: net_ratelimit: 680 callbacks suppressed
Dec 15 04:25:50 kernel: net_ratelimit: 642 callbacks suppressed
Dec 15 04:25:55 kernel: net_ratelimit: 633 callbacks suppressed
Dec 15 04:26:00 kernel: net_ratelimit: 623 callbacks suppressed
Dec 15 04:26:05 kernel: net_ratelimit: 620 callbacks suppressed
Dec 15 04:26:11 kernel: net_ratelimit: 613 callbacks suppressed
Dec 15 04:26:16 kernel: net_ratelimit: 978 callbacks suppressed
Dec 15 04:26:21 kernel: net_ratelimit: 1001 callbacks suppressed
Dec 15 04:26:26 kernel: net_ratelimit: 694 callbacks suppressed
Dec 15 04:26:31 kernel: net_ratelimit: 644 callbacks suppressed
Dec 15 04:26:36 kernel: net_ratelimit: 642 callbacks suppressed
Dec 15 04:26:41 kernel: net_ratelimit: 687 callbacks suppressed
Dec 15 04:26:46 kernel: net_ratelimit: 642 callbacks suppressed
Dec 15 04:26:51 kernel: net_ratelimit: 609 callbacks suppressed
Dec 15 04:26:56 kernel: net_ratelimit: 616 callbacks suppressed
Dec 15 04:27:01 kernel: net_ratelimit: 619 callbacks suppressed
Dec 15 04:27:06 kernel: net_ratelimit: 630 callbacks suppressed
Dec 15 04:27:11 kernel: net_ratelimit: 649 callbacks suppressed
Dec 15 04:27:16 kernel: net_ratelimit: 639 callbacks suppressed
Dec 15 04:27:21 kernel: net_ratelimit: 653 callbacks suppressed
Dec 15 04:27:26 kernel: net_ratelimit: 682 callbacks suppressed
Dec 15 04:27:31 kernel: net_ratelimit: 643 callbacks suppressed
Dec 15 04:27:36 kernel: net_ratelimit: 630 callbacks suppressed
Dec 15 04:27:41 kernel: net_ratelimit: 631 callbacks suppressed
I tried doing a google search, but I didn't really understand what the problem is exactly, as every page I read had a different solution/issue.
Can somebody please explain to me in layman terms what's going on, and any solutions? If you need anymore info, LMK!!!
<3
VvV
As soon as I ended my PUBG match, the callback limit reduced dramatically. So, it seems PUBG is the culprit. What's going on exactly?
P.S:
I regularly get spammed with DDoS when I game(people don't like the MASTAH CHEF, & this is the reason I bought this router, was for PROTECTION). Is this what it is? DoS DDoS?? Do I have to do anything, does this even need fixed? Or do I leave it be? Somebody mentioned that I need to block it, as just suppressing the callbacks itself, causes bandwidth & processor usage.
Looks like it's likely you've got it configured and/or physically connected improperly. And, if you haven't changed anything recently, it's been that way for a while. Well, at least according to this recent forum post where they address the same message https://www.snbforums.com/threads/rt-ac5300-the-first-24-hours.45722/
Basically, make sure only one of your devices has DHCP enabled. Make sure the physical ethernet connection is going from WAN on the raptor to LAN on the Huawaei. That's the basics. If you need more help, please post more information about your configuration and how everything is physically connected.
Screenshots of the settings in both devices would be useful. And, a drawn up diagram with labeled ports of how your ethernet cables are connected.
I rebooted the Huwawei, then fiddled with some Asus settings(UPNP), rebooted the Asus, along with all my WIFI devices, and the issues seems to have stopped - for now. Got my fingers crossed!
Will update if the problem happens again.
thnx 4 the help !! man <3
