Hello,
I recently purchased the 3TB Seagate External USB 3.0 drive from Staples. Took the hdd out, put in an Antec MX-1 external enclosure, was asked to format drive, went ahead with request, but options in formating windows only show 1 for 349G "capacity". This doesn't sound right. So posted a follow up post in the Hotdeal forum http://hardforum.com/showthread.php?t=1750195&page=2
Got some help, but still can't gain the full capacity of the drive, only 746.39GB.
Thanks to BoogerBomb, I followed the steps he provided below till step 3, but still only give me 74.39GB.
Again, after performing step three above, I still can't see the full capacity of my drive. I might have missed something, but I can't see what it is. Now, when right click, I don't even see "Format" option anymore. What else can I do? What else must I do to gain the full capacity of this drive?
My system this MX-1 enclosure is running on:
OS: Windows 7
Lenovo X220 Tablet
RAM: 4GB
Thanks in advance.
1. Now, go to Control Panel, Administrative Tools, Computer Management. Choose Disk Management on the left and you should see in the lower portion of the screen a list of your installed drives. The larger drive should appear in the list with a capacity displaying on the left. Note, a 3TB drive will only have a storage capacity of LOWER than 3TB (read: when you add formatting and a file system, both of those require space on the drive, so you will not have a full 3TB of space to use-this is the nature of hard drives-you will never have the full stated capacity-ever since it is required to make the drive useable).
2. Now, assuming you're using it as a data storage drive, ensure that nothing is still stored on it and right click on the partition on the right, right click the partition (if there is one on the drive already) and click "Delete Volume".
3. Next, right click on the name on the left "Disk #" and choose "Convert to GPT Disk". Now this should allow you to right click on the unformatted space on the right and to create a new partition which can hold the full available capacity of your drive.
This should work with all versions of Windows Vista and Windows 7 (with the only exception being a starter edition *may not*).
With the variety of systems now sold using UEFI instead of BIOS, you can today on those systems install Windows directly onto a drive greater than 2.19TB in size. Just ensure that your computer actually is using it before attempting to run Windows on a drive that large. It's also probably not a great idea just due to the fact that if Windows fails you will likely lose all the data on that partition.
OS: Windows 7
Lenovo X220 Tablet
RAM: 4GB
Thanks in advance.
