Chevy-SS
- Feb 5, 2007
My current computer is in need of an upgrade.
Also, it's time to migrate away from Windows XP to Windows 7.
So, in summary, I need recommendations for:
* Mobo
* CPU
* Ram
* SSD
Many thanks for any help! Dave F. in Rhode Island
1) What will you be doing with this PC?
Some gaming, office work, and some graphics
2) What's your budget?
Budget at around $600 to $700
3) Which country do you live in?
I live in USA (Rhode Island)
Asus A8N SLI S939 Deluxe mobo - REPLACE
AMD x2 4800+ CPU - REPLACE
2GB Patriot DDR ram - REPLACE
SSD - want a good one, around 100GB
Win XP Pro - REPLACE with Windows 7
Case (unknown brand - would prefer to reuse this, pic below)
Antec True 550 EPS 12v - REUSING
EVGA GTX460SE 1GB - REUSING
1+ Terabyte HD total - REUSING for storage
Dell 3007WFP Monitor - REUSING
6) Will you be overclocking?
NO
2560x1600 , Dell 3007WFP 30"
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
No extra features needed
NO. I want Windows 7 Home Premium
Here a pic of the case. I think my current mobo (Asus A8N SLI S939 Deluxe) is standard ATX, but not sure. I really like this case so I'd like to keep it:
* Mobo
* CPU
* Ram
* SSD
NO
ASAP
