Need help troubleshooting hardware problem.
455olds
I built a computer a little over a year ago. It had a bad power supply at first but has been running good and stable for the last year after replacing the power supply.
The problem it just started having is random shutdowns ,freezing and screen tearing(also blue lines at bios screen)
It will not make it through the windows 7 performance test without crashing.
I also get a " DQS training failed on previous boot" error message.
For troubleshooting I have tried swapping the two sticks of ram,booting with 1 stick and same problem with both sticks.
I tried clearing cmos, replacing battery and updating bios.
Any advice on what my next step should be? Sound like a bad motherboard or bad cpu?
Here are the specs
COOLER MASTER Elite 341 RC-341C-KKN1-GP Black Steel MicroATX Mid Tower Computer Case
http://www.newegg.com/Product/Produc...82E16811119193
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
http://www.newegg.com/Product/Produc...82E16832116754
BIOSTAR TA890GXB HD AM3 AMD 890GX HDMI SATA 6Gb/s Micro ATX AMD Motherboard
http://www.newegg.com/Product/Produc...82E16813138194
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit Desktop Memory Model F3-10600CL9D-4GBNT
http://www.newegg.com/Product/Produc...82E16820231253
AMD Athlon II X4 640 Propus 3.0GHz 4 x 512KB L2 Cache Socket AM3 95W Quad-Core Desktop Processor ADX640WFGMBOX
http://www.newegg.com/Product/Produc...82E16819103871
ASUS PCE-N13 IEEE 802.11b/g/n PCI Express Wireless Adapter Up to 300Mbps Wireless Data Rates 64-bit/128-bit WEP, TKIP, and AES WI-Fi alliance WPA, WPA2
http://www.newegg.com/Product/Produc...82E16833320048
ASUS Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 24X CD-RW 48X CD-ROM 1.5MB Cache SATA 24X Burner LightScribe Support - OEM
http://www.newegg.com/Product/Produc...82E16827135221
Western Digital Caviar Blue WD5000AAKS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Produc...82E16822136073
CORSAIR Enthusiast Series CMPSU-650TX 650W ATX12V / EPS12V SLI Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
This is the original thread for the build. http://hardforum.com/showthread.php?t=1589007&highlight=455olds
Any help appreciated. I am at a dead end with this.
Try a different PSU and Video card. See if that resolves the problem. Perhaps pull one out of an old system if you have any laying aorund...
Might be a bad motherboard if you're using the onboard video.
It is onboard video. Maybe I should contact Biostar and see if I can rma the board? I really don't have another power supply or video card to try in it. I don't want to take apart my main rig.
i have a gigabyte 785g in my fs thread. not ddr3 but if you have some ddr2 it would work for you. let me know if you want to buy it. its micro atx too :)
ialso have lots of ati cards for sale. you could always try a pci-e card instead of onboard and see if that helps
I sent motherboard off for rma. Biostar has been really good about it so far,they got back to me quick.
Will I be able to tell if I got the same board back? Will it have a differant serial number?
They sent me a replacement board with different serial numbers. The new board is in and works good. Thanks for help,esp Danny
No prob. Hopefully that solved the issue you're having.
