OmegaSupreme
- Sep 29, 2009
As the title says, when I OC my rig it gets artifacts in game (FC2) and when I run 3dmark 06 it sort of "skips" once every second in 3 of the 4 GPU tests (the only one it doesn't do it in is firefly forest).
So here's how I have it setup
HTT(FSB): 225
CPU:3600MHz
NB:2700Mhz
MEM: DDR3 1500 @ 7-7-7-20-27-1T
GPU(s): At stock clocks
All of the above setting have been tested for stability using Memtest, Prime and S&M V1.9.1 and have passed w/o issue.
However, when I run it at this speed I get the erky jerky video during 3dm06 and when trying to play farcry 2 I get some rather large artifacts on the right side of the screen. The artifacts show up in the same place. It's not random as with a bad GPU overclock. And like I said it's rather large. On my 22" screen it's a black bar that's 3" wide by 8" tall. It only flashes every few seconds.
Any idea's as to what might be causing this?
Also, I noticed this when I got my results from the FC2 benchmark.
Initial run (@ stock) looked like this
My overclocked run looked like this
Any idea's what would cause it to have the saw tooth pattern?
HTT(FSB): 225
CPU:3600MHz
NB:2700Mhz
