Need help finding mobo and cpu combo
I will use it for HTPC and gaming.
Budget: 100+ for mobo, 150+ for CPU. the cheaper the better
The board should have optical out. I'm sick of static coming from my z-5500 analog.
SLI / crossfire is not necessary.
Should overclock very well. I may watercool in the future. I just enjoy overclocking, not because I game or any thing.
DDR2 only, DDR3 is too expensive for what it delivers
As for CPU, i prefer intel, either dual or quad. I think quad is better because I mainly use it for HTPC. As far as OC is concerned, which one is better in terms of % OC?
No need for future proofing, I change computer 2-3 years.
TIA
I'd say the same as Danny, but with a Q6600 if you're looking for a quad core. It OCs very well, and can easily get you up to 3.6 on air.
I'm going to agree with Danny on this one. And about your optical request, if you want good sound out of your speakers, ditch the onboard and get a real sound card. No matter what kind of output you use, you still won't get good reproduction without a good card.
Can this E8400 combo OC to 4.2+GHz?
Q6600 from 2.4 to 3.6 is a 33% increase, while E8400 3.0 to 4.0 is only 25% increase.
Far as audio is concerned, my goal is to avoid the static which i think may come from static on the analog jack. I suppose the optical toslink will elimiate this problem.
It is hard to find a sound card that also out put optical. All the creatives do not have optical out. Besides I would not be able to use the front audio/mic jacks.
3.6Ghz isn't guaranteed with a Q6600 either.
I have a Q6600 and a P5Q Pro. Good combo. I hooked up the digital audio (SPDIF Coax) and it works with my speakers with no static. Seems to work well.
Look for a Q6600 here on [H] with a low VID, get a nice core contact cooler, then you're good for 3.6. As kirby, I also have a Q6600 and an Asus P5Q Pro, and it has very nice onboard audio and no static.
