Thanks,
Tried that already, doesn't provide many of the options..
lol this thread is still going 2.75 years later
Thank you so much for this awesome utility! Would it be possible to enable "Prompt User" from the command line, such as remotecontrol computername -prompt?
Thank you!
https://www.virustotal.com/en/file/90b3c9201459652f4305965a4d06585b705b73d96805c95df6bb07cbc27556e6/analysis/1372272605/
http://wikisend.com/download/388388/RemoteControl.zip
1.7.3 Release
Here are the changes:
1.7.3:
1.) Added new command line option of "--prompt" which will enable prompting the user by default.
2.) Changed How it Works page to reflect above change.
3.) Added an error message for command line options if arguments are invalid.
4.) Upgraded TightVNC Server to 2.7.7
Your software is wonderful! I have one suggestion: Can you please make a status bar with information that is going on (Connecting, Cleaning Up, etc). It's a bit hard to notice now on the command button that is greyed-out.
Also,
Have you resolved the issue with the leftover file in the RCTEMP folder? I noticed that it was left behind on both a 32bit XP machine and a 64bit Windows 7 PC.
Perhaps it's possible to add a function that kills whatever process is locking the file so that it can be deleted. Similar to how Unlocker or FileAssasin work.
I think a status bar would make it more obvious as to what's going on. It should also display if there was a problem with clean up IMO. Regardless, this is a great program and I think it deserves its own homepage.For whatever reason, the first time you connect to a device it locks that screenhooks.dll file in the RCTEMP folder for an undetermined amount of time. I think this has to do with the way the VNC server hooks into the OS for viewing the screen. I kind of gave up on the whole thing because no matter what I did the file would randomly stick around. In theory I could add a scheduled task on the target computer that would repeatedly try to delete the file until its gone and then delete the task.. but im not willing to do that. In most cases, reconnecting and disconnecting from the machine will remote the folder as designed.
The connecting cleaning etc process notification should be very visible even when greyed out. There is also a progress bar at the bottom that moves when the application is busy. Is that not adequate enough? I guess I could also change the cursor to the busy cursor.
https://www.virustotal.com/en/file/998b679cf66d7558ef3c87d433603a68d456c6b06cba0350826616e3a5d5880a/analysis/1379978664/
http://www.tschantz.name/RemoteControl/RemoteControl.zip
hello!
been playing with this for a few weeks now, and love it, thanks. its nice to finally have a replacement for gencontrol
i've discovered a problem with it connecting to a win2008 r2 x64 server though.i just get an error from vnc viewer "connect: Connection Refused (10061)"
im guessing its something to do with either a security policy on the domain/gpo, or some potential setup issie with the server (its a brand new box i just built)... any ideas whereabouts i should be looking? (im running your app from my win7 x32 laptop)
cheers,
w.
A couple of small suggestions:
It would be great to be able to double-click on an entry to start the remote connection.
Also the ability to sort by name, etc in the hosts list or even export it then re-import.
Ability to leave the VNC software on the remote computer if desired, maybe customize settings as well.
Choice of whether or not to save the PC to the saved hosts list.
Ability to remove single or multiples from the hosts list with shift, control, etc and the delete key.
Other than that I can say I love this tool so far, just found it yesterday, will send a donation your way....
Interesting that you are getting that error about connection refused.
When you get the error can you check the remote computer (don't close the error window) and see if the VNC Server is running and started? Additionally can you also check to make sure that the port is open (5993)?
Thanks
[tvnserver.exe]
TCP 0.0.0.0:5900 0.0.0.0:0 LISTENING 3336
[tvnserver.exe]
TCP 0.0.0.0:6014 0.0.0.0:0 LISTENING 1628
Maybe a stupid question, but how do I go about making a donation?
"I wont ever add an export option though as technically all the hosts are saved to a text file in the APPDATA folder already."
Oops, I missed that somehow, guess I shouldv'e RTFM....
ok, when i run it, it spawns two tvnserver.exe processes at the other end. one owned by my user (who has admin rights on the box), one by system
netstat shows the following two ports:
Code:[tvnserver.exe] TCP 0.0.0.0:5900 0.0.0.0:0 LISTENING 3336 [tvnserver.exe] TCP 0.0.0.0:6014 0.0.0.0:0 LISTENING 1628
but no mention of 5993 being in use
anything else you want me to check?
the port *should* be open... the firewall is currently disabled while i'm testing stuff before go-live.
*edit*
the WMI service is running and set to automatic startup if thats any use to you...
And this is on server 2008 R2?
Is UAC enabled?
Strange indeed.
yep, 2008r2 x64 with UAC...
Can you as a test disable UAC and see if it makes a difference?
cant at the moment, as i put the server live yesterday and cant make changes to it anymore without going through the change control process we have...
however, i'll be building an identical box next week, so will be able to test it on that before it goes live... will check back and update once i've built and tested it
Hi Muad'Dib,
Speaking of UAC - is it possible for Remote Control to include an embedded manifest to force it to prompt for Admin credentials when run under UAC?
I don't *think* it's hard to do - the following pages describe the process:
http://msdn.microsoft.com/en-us/library/bb756929.aspx
http://stackoverflow.com/questions/2432329/how-do-i-deploy-applications-in-run-as-administrator-mode
At the moment we have to set this manually via a shortcut. If the manifest was included in the executable, this would not be necessary (and surely everyone needs to run this as Administrator anyway?)
Kind regards,
Chris
'Another small thing:
When you disconnect from a end user, after the session closes & it goes through and removes VNC from the PC, it needs to clear the Host Name & Description boxes if possible.
Also how about an option to save the windows position when it's closed?
https://www.virustotal.com/en/file/8842baf9aeca31fd9d3ad9c7025b875bf276b25e596adc4fc63340986351254d/analysis/1386119072/
http://wikisend.com/download/267280/RemoteControl.zip
Currently, the process for this application has always been to do a Shift Right Click-->Run As Different User. I don't foresee that changing that in near future. It does what it needs to do without adding even more complexity to the application.
That's fair enough - but this would mean that you wouldn't need to right click - just double click and it will auto-run as Administrator (UAC will prompt if necessary).
I think it's as simple as setting an option in the Visual Studio compiler:
http://msdn.microsoft.com/en-us/library/bb384691.aspx
Open the project's Property Pages dialog box. For details, see How to: Open Project Property Pages.
Expand the Configuration Properties node.
Expand the Linker node.
Select the Manifest File property page.
Modify the Enable User Account Control (UAC), UAC Execution Level, and UAC Bypass UI Protection properties. I think you want 'UAC Execution Level' of 'requireAdministrator' and 'UAC Bypass UI Protection' set to False.
This will not create any additional complexity - just next time you compile, the executable will flag itself to run as Administrator. Let me know if you're still unsure - but I think it might fix the problem above too![]()
http://netload.in/dateiZ2hMLpQ0rb/RemoteControl.zip.htm
Thanks for sticking with it and pointing me in the right direction. I have implemented the change (albeit a bit different than what you posted) and it appears to work as designed in the limited testing I have done.
Are you willing to try it out and test?
I noticed one small hiccup:
When you select & delete a host, it clears the host name field, but does not clear the Description field.
