Tamlin_WSGF
- Aug 1, 2006
Yes it will use the full 12 bit. The document you arelooking at was written regarding the Medical Series and 80 Series LCD's which only use a 10 bit LUT.
Are you sure about this? The reason I ask is that this documentation correspond with the same that came with the CD. Also, the index in the gammacomp program only goes from 0-1023 per RGB (which gives 1024/10-bit if to count 0).
Edit: I know the monitor supports 12-bit, but do the program really support it as well?
