Eco and auto brightness are definitely off. I have brightness at 0%, contrast at 50% and sRGB selected. To me a black screen in a dark room doesn't look black at all. If I watch a dark black and white film it becomes very apparent that the black bars on the sides of the screen are not black. I have no way of knowing what my black level is though, because I don't have any calibration equipment. What settings did you have to alter to achieve 0.2cd/m^2?You may want to verify that Eco mode and/or auto brightness are off if you're finding the brightness to be too high at 0%. I don't find the brightness to be excessive at all, even at around 20% in a dark room. Calibrated, I got 0.2cd/m^2, so it basically looks like it's off when displaying a black screen.
I avoided getting an LCD monitor for years because I was worried about poor viewing angles and low black levels. The viewing angles are fine wlith this monitor but I'm not sure I can get used to the blacks. I have to view and work on my own films in darkness because they are experimental 16mm films that were specifically designed to be viewed that way. During lighter scenes in the films it looks absolutely amazing though. I'd only need the blacks to be slightly darker to find it just about acceptable. Maybe that could be fixed with calibration.In the dark I find that too bright and black doesn't look black.
IMO LCDs aren't really made for use in the dark, they work better with ambient lighting.
