maclem8223
- Oct 28, 2013
Great info, thank you. I knew the specs on the Silent Loop but wasn't sure about space "in the case". I will stick with the Be Quiet fans for now, they will go with my color them any how; if not I have some NF-F12's I could use. The industrials would have been for aesthetic purposes really. Want this case to have a specific look. So I'm good with 1x3.5 hdd in the bottom(back) and a 92mm, 25mm thick in the bottom (front) under a 1070 a fe?Silent Loop is 30mm thick so you can use 25mm fans no problem. I would try the included fans from Be Quiet before the Industrial Noctuas, Be Quiet makes really good fans and the Industrial are supposed to be pretty loud. They move a lot of air but they are 43.5 dB(A). the included Be Quiet are 36.9 at max and 23.8 at 50%.
92mm fans can be difficult to mount in the back with a 240mm radiator installed, but possible. I can tell you that the air will exit the top of the case with no problem.
