According to this post, none of the Asus 9xx series Strix cards fit:
http://hardforum.com/showpost.php?p=1041779833&postcount=17298
thx dude. Will be w8ing next generation of gtx
thx dude. Will be w8ing next generation of gtx![]()
Hi [H]ardForum,
This is my first post on [H]ardForum, but I've been lurking here for quite some time. This thread especially helped me with my first NCASE M1 build. The case, as you all know, is extraordinary and I'd like to thank Necere and Wahaha360 for making it happen. You guys have amazing talent.
Now, the reason for my post.
I have a couple of outstanding issues with my build that I would like to address.
First, here's my build (if you want screenshots I can provide them):
Case: NCASE M1 V3
CPU: Intel Core i7 4790K (stock speed, no oc)
CPU Cooler: Corsair H75, with push/pull 2x NF-F12 intake (yes both fans fit with lots of room to spare)
Motherboard: Asus Maximus VII Impact
RAM: 16GB Corsair Vengeance LP
GPU: Geforce 780ti with Corsair HG10 N780, Cooled with H75 and single NF-F12 intake (only 1 fan fits here)
PSU: SilverStone SX600-G (mounted with fan intaking air from outside)
Temperatures with current configuration:
CPU Idle: 32C
CPU Load: 67C
GPU Idle: 28C
GPU Load: 58C
1) SX600-G PSU is loud and runs quite warm under load. The issue may be compounded by the fact that the H75 for the GPU is blowing hot air directly onto the frame of the PSU and subsequently the rest of the case. The air coming from the top of the case near the PSU / GPU H75 is very warm and makes the top of the case hot to the touch.
Could this impact the PSU at all?
Would the 500W SFX-L alleviate the noise issue?
Should I hold out to see what Corsair's 600W offering can do?
2) Should my H75 fans be mounted as intakes or would exhaust be more appropriate with this configuration? Or would intake on the CPU fans and exhaust on the GPU work better?
3) The H75 cooling the GPU gets quite warm to the touch, but temps seems great. Is this normal?
Thanks
Papadoc
Did you modify the bios on your card? When I installed the Accelero on my gtx 970 with two NF-S12B Redux I had to use the Maxwell Bios Tweaker to adapt the fan settings to fit the specs of the NF-S12B Redux. I didn't manage to get the correct fan speed using software like evga precision. I tired a couple of others as well before I tried tweaking the bios. I believe if you have blower card, the initial fan settings will be far off from that of a nf-f12 fan. After my bios tweaking the fans were barely audible and temps were between 40C and 75C.
You should look for a guide if you're going use the tweaker and nvflash, I think you have to disable the card driver before doing the changes.
I see some people use the tweaker to stop the fans completely when not gaming, but I'm not sure if that works with all fan types.
I can post my Maxwell Bios Tweaker fan settings when I get home, if that is of interest.
Are these temps normal?
Installed my 500W SFX-L in my ncase v2 the other day using the new PSU bracket but I can't see a way to get a gpu in there, there are just too many cables coming out.
The cables should bend towards the other side of the case away from the GPU, then loop back towards the motherboard side. And you have to jam in the GPU and the cable will definitely be touching the GPU but it works.
Bend to what side? I tried to bend them towards the right panel but can't get them all tight enough to allow for a gpu.
is your CPU getting that hot?
The top heatsink can possibly be forcibly kneaded to be more centered. But this involves bending the heatpipes to some extent and depends on whether you dare to do it. I've done it on three top-down heatsinks before: the NH-L12, the NT06-Pro and the Kabuto II, and they didn't break or anything.
anyone got any ideas on whether or not the Palit GTX980Ti Super Jetstream will fit? it seems like it would be a pretty tight squeeze given the 2.5slot cooler and the 280mm length of card. im tempted to snap up a 980Ti and the palit is arguably the best/quietest card and definitely the cheapest option in AUS
Dimensions of the card are 28.0 cm x 13.5 cm.
how much work was kneading the Kabuto to fit flush against the fan+bracket? Any tips on how to work it without breaking, causing metal fatigue, hurting myself, etc.?
I've got an M1, Kabuto II and Asus Z97I-PLUS en route and have this lofty dream that I might get the heatsink lined up so that an NF-F12 clipped to it might screw neatly into the fan bracket.
If anyone has any experience with the Kabuto II on a Z97I-PLUS I'd appreciate any tips...
I'm hoping to orientate the heatpipes to the back and use a NF-A9 to bring in some extra cool air onto them for an intake-up-top and exhaust-down-below setup like cowsgomoo and Phuncz. Not very original, I know! I think it was seeing Phuncz' glorious 4x NF-F12's and his benchmarks after cowsgomoo's tip that sold me on it (thanks guys! really appreciate your posts!!).
The kneading is really easy after you remove the clamp.
But it can't be flushed perfectly. I had to use 2x2mm fan silencer as a short tunnel between the bracket and the fan, and so that the fan almost touches the Scythe Kabuto II. (The effect of this may be placebo)
SilverStone also seems to be advertising a 5mm fan silencer on their website and that may also work as a tunnel.
However, the purpose of removing the clamp and adjusting the Kabuto II is because of manufacturing error. The heatsink is not level because the clamp pulls one side of the heatsink too close to the motherboard. So to prevent my OCD from acting up I removed the clamp and readjusted the heatsink to make it level.
I tried the NF-A9 as well but without a downvolt adapter it was too loud for me.
Do you also plan to use the accelero cooler? As bottom exhaust is optimal only with that setup.
I have that power supply but I don't have that problem. Have you tried with another power supply ? It could be the PSU or possibly even the motherboard. But I'd first investigate with another PSU.
Hi guys,
I know some people here are using the same powersupply that I use, so I hope you can help me. I use a SFX-L SilentStorm Gold (500W) in my NCASE (2600k, 560ti, 1x 3,5" HDD, 1x 2,5" HDD, 1x SSD; custom loop).
Some time ago I found that my power supply wouldnt work after a shutdown. If I restart it after running for a while it would cycle on and off constantly for atleast one minute before finally starting properly. If the system isnt used for a while and cooled everything is fine and the pc starts instantly.
So I wonder if other people have the same issue with this power supply (maybe its normal?) or if someone knows a reason for this behaviour. Otherwise I will RMA it, but wanted to ask here first.
Hope someone can help me =) thanks in advance
my system (which is dead now) used to do something similar; not exactly the same, but similar. once in while, it would shutdown by itself during sleep or while it was on, and restarting it would cause the system to cycle on/off for two or three times (not for a minute) before before finally starting. one day, the system shut itself down during sleep and never woke up. for me, it was the motherboard.
I'm tired of waiting for Corsair's SF600. Since I'm moving everything from my Version 1 to my new V4, I might as well take matters into my own hands. To heck with Silverstone's warranty sticker!
I finally got around to installing the new V4 SFX bracket and new fan bracket with magnetic fan filter in my version 1 M1. The SFX bracket fits perfectly. The new fan bracket not so much:
http://i.imgur.com/eJo9Znsl.jpg
A little bummed but I can confirm another misfitting fan bracket. Is there anything that can be done about this?
