NCASE M1: a crowdfunded Mini-ITX case (updates in first post)
Read somewhere that V3 brackets will be available in a couple of months, got any more info about that?
Not sure where you read that, but the V3 SFX brackets won't be produced again until and unless there's another M1 production run. Lian Li requires a 1,000 unit minimum order for a small part like that by itself, which makes it unfeasible to do. If we attach it to a production run, it's no problem to make a couple hundred extra.
Ok, don't remember exactly where I read it. But I do remember the post was made in Swedish, might just been the language barrier making the poster misunderstand something you or w360 told him.
The search function is your friend--found in less than 10 seconds. Just searched "nzxt", was the second or third result.
Thanks! I totally didn't think to use the search thread feature since some of the other forums I usually use don't have it =P
Ah, forgot about that, you'll want to add 1.07mm to both the X and Z measurements.
I'll leave the survey up for a few more weeks but if there isn't a big influx of interest I'll probably drop the project.
Well if it's any consolation, I just filled in the form. :)
Has anyone replaced their V1 panels with V3? How much of an improvement is it?
Just got put my M1 PC together. Was much more simple than I anticipated, as packed as it appears when it's done, I never felt all that cramped or frustrated putting it together. This case lives up to the hype.
Only issue was using the SFX-L PSU and fitting the 970 behind it, I had to bow the board a bit to get by the cables, but I was anticipating this.
Congrats! Hopefully mine isn't much further away. I know we ordered around the same time.
Hi. So just in case anyone is wondering.
2 noctua 120mm x 25mm fans bolted on a 38mm radiator will not fit. At least if you are using a swiftech pump/cpu cooler combo.
Just wanted to inform you incase anyone of you are as dumb as me and fail at measurements and basic math. Works with one fan though so I got that going for me.
All of the slim rad (under 38mm)+2x fan setups, including H220 I've seen seems to fit snugly. Which component inside the case is blocking the fan+radiator from being fit in?
All of the rad+2x fan setups, including H220 I've seen seems to fit snugly. Which component inside the case is blocking the fan+radiator from being fit in?
I would imagine the Apogee Drive II is the cpu cooler and pump combo in question? It's quite tall especially if you have 90 degree adapters (which you pretty much need).
(source: http://www.swiftech.com/ApogeeDrive2.aspx#tab3)
I recall a hardforum member made this build log
http://translate.google.se/translat...9331-bygglogg-ncase-m1-varning-mycket-bilder/
Used an Apogee Drive II and EX240 rad (35.5mm) + 2x Noctuas (25mm) measuring 60.5mm but with the bracket attached it'll push over that thickness by a few mm. I'm assuming Locrin might be using PE240 (38mm) with the Swiftech waterblock but from the excel build log there have been some users that are able to fit that combo in.
Finally received my silver panels ^^
the case looks awesome with the front IO ports covered with black USB and audio jack rubber stoppers.
Hi, sorry for late answer guys. Didn't think anyone cared about my little rant/self ridicule.
I used the EK Waterblocks EK-CoolStream PE 240 and two 120mm x 25mm noctua fans. And yes I was using the Swiftech Apogee Drive II Incl. MCP35X Pump. The way the tubing extends makes it impossible (at least for me to fit). And now it is leaking. I might be bad at this.
What are people's experience with the Demciflex filters? I thought it was a great idea having magnetic filters, but then these don't work with aluminium. Instead there is some kind of adhesive on them... Won't the adhesive wear out? Can it be conveniently replaced when needed?
There are adhesives strips that attach to the case, and the filters attach magnetically to those. The strips themselves aren't meant to be removed.
I see, thanks for clearing that up. :) It's not a super convenient solution, if you ever need to remove them due to different airflow configuration or so, I guess.
My experience was that the mesh itself has a bit of slack that led to the mesh getting pulled into the fan blades a bit. Nothing that would impede the fan from turning, but it does create additional noise. I never got around to swapping it so that it would go filter -> rad -> fan, that may have solved the issue over going filter -> fan -> rad
Have you ever been proud of something but ashamed at the same time? Kinda how I feel now.
I made it all fit. The 38mm radiator with the 25 mm fans. Have some pictures of my ghetto build.
http://imgur.com/a/KCatB#0
I don't think it could be any tighter. The fans are pushing on the switftech apogee pump making the motherboard bend slightly. But it boots, and it is dead quiet* idling at 40 degrees celcius. Would love some feedback both good and if you are horrified and want to tell me how ashamed I should be.
Also there is a screw stuck in one of the holes that I had to drill the head of.
*as quiet as you get with no sound dampening material.
The gpu is not watercooled (yet) and is not plugged in as of this moment just in case it starts leaking overnight. But it should be trivial adding watercooling to the gpu if I ever want to do that.
edit: Aaaaand apparently I don't have room for dust filters.
Their filters are relatively cheap enough (compared to the other components in your build).. just order enough to cover everything that you would potentially use as an intake, and only use what you want/need for a particular config (or maybe just request additional metal adhesive strips for moving the filters to different locations).
Right now, I have 2 on the bottom, 2 on the side panel (only needed one there), 1 on the PSU, a large one under the top panel, and a few extras as spares. Think I'm out ~$80 due to the spares, and from having originally bought Necere's design for the side panel, then later swapping those out for IreK's 1-piece design. In retrospect, that seems kinda pricey for what I'm actually using.. but I'm sure I've wasted just as much on much dumber things :eek:
I had the same radiator and pump/block combo in my M1v1 build, but with the pump rotated 90 degrees (with VLP RAM), and corsair fans. I still had similar issues with the fan pushing on the fitting and pump, but I fixed it by using a rotary tool to cut away the part of the fan chassis hitting the pump... it doesn't need to be much.
I could do that, but the fans were kinda expensive and I don't have a tool like that anyway. It ran fine all night so I'm going leave it like it is. If it breaks I have a good reason to abandon watercooling for good. It is not for me I think. Kinda fun to "plan" and build but too much of a pain in the ass to maintain.
Here are some photos of SX500-LG with Gainward GTX 970 + Accelero Xtreme IV:
I've cut down the original VRM cooler to fit with the accelero.
Clearance:
(Sorry for potato quality.)
Real silent stuff :D
Nice one. It's good to see the Gainward is as short as I thought it would be. Might even convince me to go for an air cooled setup. :)
:D
A lot of people went with the Demciflex filters, but for quite a few reasons I instead got essentially a fan filter panel (http://www.moddiy.com/products/-Ultra-Thin-PVC-Twin-Fan-Dust-Filter-(12cm{47}14cm-Fans).html). It's stated to be 0.17mm thick, and I put that outside the fan bracket.
Cutting the fan housing is okay, a bit DIY-intensive but definitely do-able; if you don't have the right tools, yeah don't attempt. I don't think you should abandon watercooling! The M1 is also my first watercooling attempt and the limited space and component choices certainly make it more challenging. It's well worth it and you've come a long way already!
I wouldn't feel very comfortable with the motherboard PCB being stressed by the radiator pushing on the Apogee Drive ii, so I'd probably swap out the radiator to a thinner one. It might seem like a setback but that's all it should be. By now you should be a pro at tightening the fittings right? :D
And I would also say why not get that waterblock... the fewer times you have to mess with the loop the better, as you've already experienced the fun of a leak.
This has been my experience as well when I used them on my aluminum Caselabs SMA8. VERY annoying. I wanted to put the filters on the inside of the panel to avoid having the ugly magnetic strip on the outside. Unfortunately the slack is an issue and the magnets are too weak to let the filter stick to the outside through the panel. I don't know if this would be possible on the M1 where the panels are a little bit thinner.
Thank you, that helps numb the pain in my fingers.
Yeah not proud about that motherboard thing. I could get a thinner radiator quiet easily for cheap so I should do that. Would be nice to get the filters to fit also. But I am a very lazy person so I might just pretend everything is fine.
My fingers are scarred from the sharp edges of the case, fittings and radiator. I also always get the watercooling liquid all over my hands. And it's black so I look dirty even after scrubbing for days.
Oh I will get the waterblock. It's just that they are expensive and difficult to find for the Zotac 970GTX.
Hahaha, that brings back memories of my M1 build...sore fingers for days
Well, good luck but you know it's never a problem until it is a problem! :D
What fluid are you using? With the case/loop being so small I went for maximum minimal maintenance (heh) and did distilled water + killcoil only.
Ah. Best of luck.
Some fittings are compatible with wrenches and others have tools. I don't think I would go for hand-tightening fittings unless I had a very good reason to do so!
Mayhem pastel pure black. Such a bad idea, especially since my tubing is solid black as well. It was mostly so the reservoir would be black like the rest but clear water would have worked perfectly fine. Oh well, learning by failing I suppose.
Does the Arctic Freezer 13 fit into the M1? I'm just worried because according to arctics product page, the cooler has a height of 130mm. The exact maximum for the M1. Can I still install the side bracket with such a cooler?
Assuming a ~8mm tall CPU socket, there's actually just about 132mm between it and the bracket. So anything less than that should be fine.
Yea as ghostwich said, not something to try if you don't have the tool. I happened to so it worked out. The thinner rad is probably the best route.
I totally understand the reluctance to tinker with the loop once it's done. It's a major pain to get it all built in that tiny space. Congrats on finishing it though! It gets easier each time, so don't get too discouraged. Plus, if you successfully built a loop in an M1 you can pretty much build one anywhere.
Hey Guys,
This is my first time building a PC so I want to ask for some assistance. The following components are what I plan to put into my NCase M1, once it gets here.
Case: NCase M1 V3 (No Optical Drive)
Motherboard: ASRock H97M-ITX/AC Mini ITX LGA1150 Motherboard
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler
Graphics Card: MSI Radeon R9 290 4GB TWIN FROZR Video Card
SSD: Crucial BX100 500GB 2.5" Solid State Drive
PSU: Silverstone 600W 80+ Gold Certified Fully-Modular SFX Power Supply
My biggest concern is with the GPU... will it fit? is a 600W PSU enough?
Also, I want to put two fans on the bottom of the case as intake but am unsure which ones I should go with. Any recommendations would be appreciated.
Hey Guys,
A 600W PSU will be plenty. Using a PSU calculator I got a recommended 430W for your build. That is with a CPU clock of 4.5GHz.
Just to offer even more assurance I have had almost the same build since October 2014 and it runs very well. I have 16GB RAM, custom liquid cooling, an SSD and a standard HDD, 2 fans and a overclocked 970GTX and 4690K.
Your GPU of choice is more power hungry than mine, but it should be fine overall. ITX boards draw less power, prosessors these days draw very little power, SSD's draw very little power etc. As for GPU compatibility I want to say yes. But check the size of your version of the 290 against this the numbers on the compatibility tab here https://www.ncases.com/
Hey Guys,
Hi. Welcome to the Forum.
1- The GPU Should fit just fine. The 970 with the same cooler is a confirmed fit on the spreadsheet.
2- 600W is comfortable. You could get away with the cheaper 500W SFX-L PSU as well, but that has some clearance issues with long GPUs.
3- Is there a specific reason for going with the Asrock board? The Gigabyte GA-H97N-WIFI is cheaper. Also, keep in mind that in choosing an H97 board instead of a Z97 board, CPU overclocking is no longer an option. Worth a mention since your going for a 240mm AIO instead of 120mm. If you're not overclocking you don't need a cooling solution that beefy. You can even get away with a decent air cooler for less money.
4- I would start off with no fans. If temperatures are ok, then you don't need them. Choosing the right fans can be a PITA. Noctua's fans are very popular but expensive. Corsair make good fans for a more budget oriented build. One thing i like about them is that they idle pretty quietly when not ramped up. Make sure to get pressure optimized fans, due to the restricted airflow in that area of the case.
5- 500GB SSD is a good call imo if you have the budget for it since it can holde a quite extensive steam library installed.
I'm guessing this is primarily a gaming machine?
Edit: And the quick draw round goes to Locrin:cool:
Edit2: @Locrin. You have a Z97 MB right? With the CPU overclocking and all... If not, my advice #3 is horrible.
@chaeid
You should get a Z- board instead of a H- board for overclocking. Like the Z97M-ITX/ac. I assume you're overclocking since you're throwing money at H100i and a -K CPU.
You can overclock on all Asus motherboards. Doesn't matter about chipset for overclocking any more.
if youre looking for big OC's the Z series still offer better power delivery/stability than the majority of other series mobos - which is something peope should def think about depending on the numbers people want to aim for. but i agree - any OC under about 4.4ghz shouldnt worry a H series at all
Long time lurker/follower of the ncase m1, about to jump on finally buying my parts. Two quick questions...
1. Can you use the dual 3.5" HDD mount along with the dual 2.5" SSD mount? I'm hoping to get 2x 4TB 2.5" drives along with 2x 512gb SSD all in the system.
2. See anything wrong with the system's part list? http://pcpartpicker.com/p/tgssgs
