OmegaAvenger
- Sep 25, 2007
me either
got in on the second beta. I wonder if we'll be able to piggyback off the switch from the previous beta.
Well I had to not go for the beta this round sadly. I really wanted too, but a last minute trip came up and it happens to fall directly during the beta period
Maybe next time.
have to pick mine up from fedex..
while were back in beta.. have you guys noticed an abnormally high readings for temps on the switch? I have it email me temp alerts and here's an example of what it's been spamming me...
Alert: Current temperature: ambient 41 C [105 F] chip 94 C [201 F]; ambient exceeds 40 C limit
Occurred at: Jul 24th 2009, 05:55 PM
Account: xxxxx
Serial: 100100046942362
the room that the switch is stored in is averaging about 72-74 degrees.
Any of the vents blocked or anything?
My indigo version runs very cool, albeit very loudly
I'm going to pop one open at work and see what it has to offer for voltages. Methinks that if the fans where to run at 7v as opposed to 12, they could be bearable.
So, I got my Cobalt all fired up and in the rack. Activated it and then started playing. Set the native (untagged) VLAN to 32 to match up with my Cisco switch, set the static IP/subnet/gateway/DNS. Setup my trunk port on the Cisco and I can ping it and access the web gui. Started plugging stuff in and all of a sudden the web gui doesn't work anymore. Cycled power and I get the web gui again. Not a big deal, could be a fluke. Set the first access port as untagged on VLAN 32 and hit the save button, web gui times out for 15 seconds and then comes back. The same thing happens when I configure all the other ports. I am hoping this isn't a "feature"?? I understand that this software/service is supposed to run on other vendor's switches but jeez, configuring ports on this thing is a real pain in the ass.
Also, if you got to mynapera.com/debug, you can reset it back to factory settings iirc.
There was another page too you could get to but I don't remember off the top of my head.
usb null modem cable as is usb to serial null modem or an A to A cable?
Anyone hacking their switches or modding them?
I took the indigo switch home from work, I am copying the files from it now, going to see whats all there...
root:*:0:0:root:/var:/bin/false
altus:*:100:100:altus:/var:/bin/false
support:m9XIf6UMsU352:101:101:support:/tmp/support:/bin/ash
nobody:*:65534:65534:nobody:/var:/bin/false
Captain,
There should be a link to a PDF of the guide in the confirmation email you received. If there was not or you cannot find it, PM me and I will send you the PDF.
Its all on their site:
http://www.napera.com/cobalt
It's a bit disapointing the cobalt doesnt have the radius server feature that the indigo did.
Were you able to eventually get all the files scotty8? it would be cool if the cobalt could be turned into an indigo.
Ya, I tried with the radius server and never got it working. I dunno if it was just me or if it was not really working.
as unlikely as it is, it would be cool if this software ended up on cisco/linksys/netgear prosafe/etc. stuff.
i think its more likely to end up on other brands before the bigger names see it. such as extreme, foundry, etc.
Our goal is to make the Napera web service widely available on a range of network devices, including switches, firewalls and wireless access points from multiple vendors. As mentioned above, the Cobalt beta is all about testing the web service. The switch hardware, and the local switch UI are really just a platform to beta test that for Cobalt.
We are working to resolve most of the beta issues reported last week - thanks for your patience. Ironically a lot of the switch side issues seen in the beta are due to the embedded switch management software. In a real deployment you would be using the standard switch software from your vendor of choice in combination with Cobalt, so several of these issues wouldn't occur.
To answer another question asked earlier, our goal is to ultimately offer the authentication and enforcement features (such as RADIUS and WPA-E) seen in Indigo in a later release. For Cobalt beta the focus is monitoring. For most of our users, the ability to monitor PC's and their update status has been a compelling reason to use Cobalt. Enforcement and authentication adds a lot of complexity and we think most customers will start with just the monitoring service.
I love beta testing stuff.
When the Beta is up, I can haz indigo on my cobalt?
